ran out of money
well i put my dash all back in the other day and my seat in tonight, so i took it out to see how the seat felt..... but none of my flashers worked. is this a relay or something that went bad? ohh yeah there is nothing on the truck except for motor, trans, rat, cab, inner wheel wells, and now a nice seat
![]() ![]() ![]() Michael
Modify everything, leave nothing alone!~ ![]() ![]() |
#2 | |
Re: blinkers and flashers not working
Assuming there are no fenders yet, you'll need the exterior lights hooked up and grounded in front and rear before the signals in the dash light up.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
ran out of money
all my lights are hooked up except for the rear, when i was putting on the new steering wheel the blinkers worked, it seems to have been, when i went to got the seat and put it in and then started the truck the lights seems to have given out, or is there a ground i might be missing that is not leting it work right? the lights in the dash work ok.
thanks for all of your help, tom. i am going to work harder on finding out what is the problem, just thought one of you guys might be able to give me a heads up
Make sure your instrument cluster is grounded to the dash. I took mine out to replace the bezel and I couldn't get anything to work. I ended up making a ground wire to go from the back of the housing to the cab, and now everything works great. It just took a whole saturday chasing down every possible problem.
ran out of money
ok well i played with it a lil today, the blinkers and flashers work when the headlights are not on, but once u turn them on they don't work anymore, just the arrows in the dash stay lit up, but both of them, and that is just with the lights on.... i dunno if it is supposed to be like that because i never had the dash lights on before. thanks for everyones help
71Rat,
I had a problem with weird turn signal behavior that I eventually tracked down to a short in the dashboard circuit board. If you have a 71, you ought to be able to pull the connector off of the back of the dashboard and see how your turn signals behave then. Brian |
Your headlights may not be grounded to the core support, and are using the signal circuit for a ground. Make sure the black ground wires from the headlight sockets are grounded to the core support, and the support grounded to the frame.
69 GMC K10 ..some restoration required....still.. ![]() |
ran out of money
would it make a difference since my bed is not on and those lights are not hooked up? as for the other things i really can't find anything that is wrong
If the harness to the tail lights is unplugged, it shouldn't make a difference, but electrical problems are funny! Did you add, remove, or change anything electrical in the engine compartment? Have you tried changing the flasher? They can act really wierd. If you buy a new one, be sure to get a heavy duty one, not the wimpy standard one.
ran out of money
see thats the thing, i didn't change anything with the lights. thats why i am really lost on this one, guess i will be pulling the dash again. thanks everyone for your help
I'm having the same problem too. I plug my harness to the battery and my blinkers and front turn signal lights come on steady. My dash cluster lights up on the right side only. I turn on headlights and only right headlight turns on (left bulb is NOT burnt out) and blinkers and front turn signal lights stay on as well. I hit the high beam and all lights work..
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#13 |
did you check the blinker fluid level?
(sorry had to) ryan.
1987 k5 4x4...FOR SALE!!! (email for details) will eventually be replaced by a 70-72 4x4 k5 |
#14 |
ran out of money
thanks everyone for the help, as for the fluid it was topped off and actually overflowing..... i was talking to a mechanic today and he said that because i didn't have the parking lights on the blinkers with the lights on would not work... so i put them on and no difference.... he also said the blinkers should blink opposite but mine don't
#15 |
had the same problem if any of the bulbs or grounds are bad on the turn signals the dash lamp will stay solid when lights are on but usually they will still work when looking at them but the dash just stays solid.
1971 c20 prerunner |
#16 | ||
its all about the +6 inches
#17 |
ran out of money
yeah i grounded them to the motor, but nothing changed.. i was talking to my dads mechanice (well the one he has now, before i get done with college) and the one guy is a eletrical wiz and said that the rear lights have to be hooked up and the bed has to be on to make the ground connection, so we will find out when the bed goes on if that was the problem. hopefully that will b within 2 weeks thanks for all the help everyone
