05-18-2012, 06:59 PM | #1 |
Dome/ Door Jamb Switch ???
Ok so is there a fuse to the dome light? If so which one because I dont see a dome or light label on the fuse box....
2....I bought advanced auto switches that have 2 leads but they say they fit the car....Will they work with 1 lead? The old switches are rusty and i assume non function since one doesnt even push in Installed one but I still get no dome light...Tried both sides and i assume maybe i just need to ground it out or its dual output Thanks
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
05-18-2012, 07:55 PM | #2 |
Re: Dome/ Door Jamb Switch ???
anyone?
05-18-2012, 08:25 PM | #3 |
Try to wire a ground to the other terminal. Also the wiring itself to the dome light can have breaks in it. Fairly common issue with these trucks
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-18-2012, 11:05 PM | #4 |
I would make sure the bulbs in the dome lights (roof and under dash - center) are good. When the switches are installed it is easy to turn the entire switch when tightening the nut - causing the wires to the switch to twist and fray or sometimes twist off completely.
The switch should have a metal plunger, not a plastic plunger. My Haynes manual shows an orange (hot) wire and a white (ground) wire. There is a fuse for it, but I don't know which one - you would have to look for an orange wire at the fuse block. If you only have one wire in the door pillar opening you likely have another wire which fell off and is in the kick panel area - I think I fished one out on my truck by removing the kick panel and vent. |
05-19-2012, 07:03 AM | #5 |
Moderator
Dome and floor lights share the same white ground path but some years they are on different power feeds.
GM calls the floor lights Courtesy lamps. It's fuse is usually marked CTSY or something similar. It's usually shared with the tail lamps. The Dome could be on the CTSY, STOP LPS, or STOP LAMPS HAZARD fuse. I'd need to know what year your cab is to be sure. If the power feed is good then grounding the white door switch wire or turning the headlight switch to the DOME position will turn the Courtesy lights and Dome light on.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-19-2012 at 07:09 AM. |
05-19-2012, 10:08 AM | #6 |
Gettin It One Pice At A Time
On my 79 the lights are hooked up to dome/cargo and horn. My door jamb switches are just one wire to ground out the system and work some of the time because of how poorly they fit. Try the horn fuse.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
05-19-2012, 02:13 PM | #7 |
Hmmm horn works, turning the light swithc does nothing, and I looked at the blub and it looks good...crazy ok ill test some stuff thanks
05-19-2012, 02:22 PM | #8 |
ok well I verified the bulb is good and found the crtsy slot...Its with the hazards and the hazard lights work and so does the horn... So....Yeah...It looks to be wiring...Thanks guys.....
Also are the hazards suppose to just stay on and not blink at all?
05-19-2012, 04:49 PM | #9 |
No, they blink. Sounds like a wiring goof somewhere, hazards could be the relay. Do you have a cargo light? If so, is the switch in the right position? I had a major short in the inside light that started to melt the wiring and blowing fuses. I replaced the light socket and new door switches and works like a charm.
05-19-2012, 04:55 PM | #10 |
hmm no I turned it on with the truck off but everything was solid.....no blinking at all....Now on the other hand I tested the bulb with a spare cargo light i had...I just hooked it direct to the car bat to see if it lit up...The cargo/dome light should come on regardless if i turn the light swithc all the way even if the door jambs are emssed up though right? I might try to swap the newer dome in
05-22-2012, 09:43 PM | #11 |
OK i found the problem.....It is the ACC fuse and i am not really sure why but as soon as I put a fuse in it pops!!! But at the same time I can remove the Dome light wire from above it and wire it into a different fuse....Now the door jamb switches dont do anything but the light switch on makes it work...
So are the door jamb switches wired directly to that fuse? maybe if i replace the other old fuse it will stop.... weird
05-22-2012, 09:59 PM | #12 |
78K & 79C Jimmys
two pins on the door switch?
one is for key buzzer and one for dome light
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
05-22-2012, 10:00 PM | #13 |
well the oem is only one....but still even with both wiredisconnect and no switch...The ACC fuse blows....Are those ground wires? The white ?
05-22-2012, 10:03 PM | #14 |
also you may be able to answer this...There is a wire behind the driver side tail light coming up the hole on the corner...Not attached to anything...White with red stripe...Any ideas on it?
05-22-2012, 10:05 PM | #15 |
78K & 79C Jimmys
white yes
05-22-2012, 10:17 PM | #16 |
78K & 79C Jimmys
orange goes fuse to one side of light
other side of light is white to door switch sorry no idea on the red n white one
05-22-2012, 10:20 PM | #17 |
ok thanks man
05-23-2012, 12:07 AM | #18 |
Home Built '87
It is my guess that the circuit is always hot (so that is the orange wire bringing the power to each of the light bulbs on the circuit).
Now when you open a door, the door switch completes a ground circuit to these bulbs so that the entire circuit is complete and the lights come on....that's why there are loops of white wire / the ground wire in the whole circuit. So try to think of it as a flowing river that runs in a circle (if that makes sense)....and follow your power source from the fuse all the way along the circuit....then follow your ground source(s) in the circuit as well and you might find the break that is causing this. I would first buy one new switch and install it in either side to check your switches or just ground out the circuit from both sides to see if that is the problem....then I would check the wiring that goes under the drivers side carpet near the door to see if the wiring going to the dome light is broken or grounding out along the way. Hope this helps.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
05-23-2012, 06:10 AM | #19 | |
Moderator
The problem may be the wires to the door jamb switches or, more likely, the door jamb switches themselves.
And please let us know if and how your repairs were successful. |
05-24-2012, 09:14 PM | #20 |
OK so I have the dome working except for the fact that its only if the key is in the car....If i wire it direct to the battery it will work like it is suppose to but thats a lot of work for something i prob dont need.... Either way the ACC fuse spot is still jacked and I dont know why.....I assume the power wire to it is ground out...Anyone know what wire in the engine bay goes to it??? Or how i can trace it? I sure dont want to remove that fuse thing and look at the back of it
Also the new door jamb switch are ghetto!!! The screw doesnt go the whole distance so after putting them on they were loose! I had to remove them and add a washer and of course in doing so i lost the wire in the hole and had to play fish a wire.... Needless to say after putting them back together i added electrical tape to keep it all together..
