05-19-2012, 11:12 AM | #1 |
Where are all the proper grounding points?
HI guys, I have a ground strap package and includes 2 long straps and 3 short straps. I need to know where these are to go? 2 long and 3 short...
05-19-2012, 12:31 PM | #2 |
Re: Where are all the proper grounding points?
I used the search function and found this amazing post about your subject...
http://67-72chevytrucks.com/vboard/s...t=ground+strap
Board Member #87725 My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=813848 |
05-19-2012, 01:19 PM | #3 |
"proper" grounding points???
if it runs on electricity it needs to b grounded it is not just a matter of a few random straps scattered around
05-19-2012, 02:04 PM | #4 | |
Then one on the rear passenger side frame mount to the bed behind rear wheel. The other strap goes fron the passenger side inner fender well to the frame. Hope this helps you. http://67-72chevytrucks.com/vboard/s...d.php?t=511271 This link may help you also. |
