Old 05-19-2012, 11:27 AM   #1
CRGRS 66
CRGRS 66's Avatar
New Wheels... but what are they from?
I bought 5 of these wheels, the guy gave me a beat up center cap as an example of what I can do with these. I am going to blast them, paint them black, and put fresh rubber on them for now. I will want to get some nice center caps and beauty rings for them, and having those would repaint them silver.
Can anyone tell me what year/style truck these are from? Can I get new/reproduction center caps and beauty rings for them?
Thanks in advance,
Craigerrr
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-19-2012, 01:10 PM   #2
junk4cash
junk4cash's Avatar
Re: New Wheels... but what are they from?
4 x 4 somethin'.
junk4cash is offline   Reply With Quote
Old 05-19-2012, 03:47 PM   #3
Joemomma1
Joemomma1's Avatar
80's 4x4 chevy/gmc. If you want them closed you will need 2 rear sets.
Joemomma1 is offline   Reply With Quote
Old 05-19-2012, 07:08 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
as mentioned they are the ones that come with the 80's chevy/gmc 4x4 ralley wheel..
pic:
Old 05-19-2012, 10:27 PM   #5
CRGRS 66
CRGRS 66's Avatar
Thanks, but what do you mean by "If you want them closed you will need 2 rear sets"?
pic:
Thanks, so the center caps and beauty rings will fit both the regular rally, and the 4WD rallys?
Craigerrr
Old 05-19-2012, 10:42 PM   #6
71swb4x4
71swb4x4's Avatar
The people above think you are asking where the center caps come from, not the wheels.
The wheels are aftermarket wheels, very popular in the late 70's and 80's, a lot of different manufacturers. The wheels you have to appear to be tapped for the Chevy center caps. The comment on the two closed ones simply means you will want two open for the front, so your hubs can pass through, and two closed for the back with the logos on them.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-19-2012, 11:33 PM   #7
CRGRS 66
CRGRS 66's Avatar
Okay, I think I get it now. I am 2WD, so I could go with 4 closed caps
Craigerrr
Old 05-20-2012, 12:00 AM   #8
Captainfab
60-66 Nut
I have to disagree, those are factory GM white spoke wheels that came on 4wd's in the late 70's, early 80's.
For center caps, you can use either 4 rear caps, or 4 front caps. If you use the front caps, you can fill the centyers with either small convex mirrors, or like I did on mine, round pieces of stainless steel. You can also use '90's to 2000 model 6 lug center caps. Those will require the special lug nuts.
Old 05-20-2012, 12:09 AM   #9
CRGRS 66
CRGRS 66's Avatar
Thanks Captain, I see now as well that if I want to use them I will first need to increase the inside diameter of the center hole. They will not fit over my front or rear hubs. I can probably return them. Maybe I can drill and tap holes in my Westerns to take aftermarket 70's/80's Chevy center caps, they look like they will accept the beauty rings. I know where I can get my hands on one to do a test fit. I could always blast and paint my westerns if the chrome looks dumb...
Opinions anyone?
Paint my Westerns silver, add center caps, and beauty rings?
Poor mans Rallys...
Craigerrr
Old 05-20-2012, 12:16 AM   #10
Captainfab
60-66 Nut
Those wheels should fit over the hubs on your truck just fine. The 4wd ralley wheels fit just fine, so these should too.
Old 05-20-2012, 12:44 AM   #11
CRGRS 66
CRGRS 66's Avatar
The lug pattern is correct, but they do not go over the hubs, front or rear (I tried). I have a buddy with some Machine Shop equipment, should not be a big deal to increase the ID on them.
Craigerrr
Old 05-20-2012, 01:07 AM   #12
Captainfab
60-66 Nut
That is strange. My ralley wheels fit without modifcation. Two of them are a little tight, but they do fit over the hubs and drum registers. If they are not very much too small, a sanding drum might work also.
Old 05-20-2012, 01:31 AM   #13
CRGRS 66
CRGRS 66's Avatar
Good point, I will try that first, thanks for the input!
Craigerrr
Old 05-20-2012, 07:17 AM   #14
jonzcustomshop
1961 crewcab
I have run into that problem with the 73-87 solid steel wheels a couple of times, just a hair too small on some of my trucks... the lug nuts will pop them on, but good luck trying to get 'em off, on one we had to take the lug nuts off and then pull it about 30 feet to loosen it up!
Old 05-20-2012, 09:12 AM   #15
CRGRS 66
CRGRS 66's Avatar
Good to know, I will make sure one way or another that there is a bit of clearance, thanks so much!
Craigerrr
Old 05-20-2012, 09:45 AM   #16
Chevy Fleetside
Chevy Fleetside's Avatar
Looks like those wheels came on later model trucks of the 80's. I remember though when I was a kid watching Chips and the blond cop had a chevy stepside and it had those rims on it or something similar. The story is here: http://www.pickuptrucks.com/html/sto...ups/page2.html
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-20-2012, 10:07 AM   #17
markeb01
Senior Enthusiast
markeb01's Avatar
At first I thought they were old Jackman wheels, but I see the spoke design is different. A bit of interesting history is offered on this earlier thread, especially posts #16, #22, and #25.
http://67-72chevytrucks.com/vboard/s...d.php?t=491950
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-20-2012, 11:00 AM   #18
S-31
If they don't fit over your hubs they could possibly be the stock wheels from a Jeep Wagoneer 4x4 from the 70's - 80's. They were six lug and alot of them came from the factory with wheels very similar to yours.
S-31 is offline   Reply With Quote
Old 05-20-2012, 11:31 AM   #19
CRGRS 66
CRGRS 66's Avatar
Thanks for the link, interesting read.
Great link as well Markeb, thanks!
Thanks s-31
Soliciting opinions... bowtie center caps, beauty rings, and paint them black... or paint them silver. I plan to keep the black/white colour scheme on my truck when I get to that point. I am leaning towards black, and of course I can always change my mind...
Craigerrr
Old 05-20-2012, 11:33 AM   #20
CRGRS 66
CRGRS 66's Avatar
Oh yeah, it was a very warm day yesterday, got my tonneau back on, all but one snap, and funny, that snap was not done up when I bought her
Craigerrr
Old 05-20-2012, 07:38 PM   #21
Chevy Fleetside
Thanks s-31
I think Black Wheels on that truck would just set it off. Can anyone Photoshop that here..
Old 05-20-2012, 11:05 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
That would be my thoughts too. Those are Jeep wheels.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-21-2012, 10:16 AM   #23
jchav62
1962 C-10
jchav62's Avatar
They were offered as "Styled Wheels" on late 70's early 80's Blazers & 4x4's.
This is from a 1981 brochure...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-21-2012, 05:03 PM   #24
CRGRS 66
CRGRS 66's Avatar
thanks jchav
Craigerrr
Old 05-21-2012, 05:08 PM   #25
CRGRS 66
CRGRS 66's Avatar
okay, so rinsed off the dirt and rattle canned one gloss black, and one with aluminum (all I had), you would have to imaging the P245 60 15's, the beauty rings, and the center caps. like I said I can always change my mind, could even go white which would pick up the black/white colour scheme.
Craigerrr
