Old 05-19-2012, 11:32 AM   #1
dwatts1984
Wheel Spacers....???
Looking to give my Long Bed a little wider stance. I cant seem to find anything on the market. Does anyone know of spacers or something...
86 GMC 1500 LWB Single cab
5.7L V8 350 , Turbo 350 long shaft trans swap
Currently has 30x9.5R15 tires that are in great shape, on stock wheels. Don't really want to spend the money to run larger wheels and tires... But want the look of a wider stance. Help!!!
dwatts1984 is offline   Reply With Quote
Old 05-19-2012, 11:55 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Wheel Spacers....???
search member cjbargains on ebay, he sells quality spacers. I have run them on 2 trucks so far, no problems.
bigblock73 is offline   Reply With Quote
Old 05-19-2012, 07:08 PM   #3
Mrknowitall
Spacers will work but not good to use. Mine ran them for 20years with no problems.
Wider rims and tires woth aggresive offset is the proper way to widen stance
Mrknowitall is offline   Reply With Quote
Old 05-20-2012, 09:01 AM   #4
dwatts1984
So I got a chance to look at them from "cjbargins" and Those are exactly what Ive been looking for. However in other ebay postings for the same item pretty much they say they wont work on my truck... So I discarded the idea. I'm sure they would be fine once the vehicle was re-aligned... But I'm not positive.
Just dont want to "waste" money on something only to find out they dont fit! How did you like the look of them on your truck. Did you get the 2 in???
Old 05-20-2012, 12:11 PM   #5
bigblock73
yeller
bigblock73's Avatar
I ran 1.5" spacers on the rear. They will work...he sells 5 on 5 to 5 on 5 spacers...just contact him and ask the question.
Is your truck 2 or 4 wheel drive?
Old 05-20-2012, 11:59 PM   #6
Mrknowitall
INCH!? Yuck. Thats SOOOO much more leverage on that poor hub/ studs. I HIGHLY reccomend u DO NOT use spacers.
Old 05-21-2012, 03:11 AM   #7
joe231
joe231's Avatar
I ran 1.5" spacers on my CCSB with no problems...
CHEVY ONLY
Old 05-21-2012, 04:10 AM   #8
baclay9
I don't see what the difference would be between running spacers and deep offset wheels?
baclay9 is offline   Reply With Quote
Old 05-21-2012, 07:57 AM   #9
dwatts1984
The difference is simply price. A set of spacers will run about $160... While deep well wheels can run about almost that per wheel, plus the cost of tires... I'd love to have deep well wheels with like 31's but... dont have the dough to pull that off.
D
Old 05-21-2012, 02:54 PM   #10
hartbraker
Hauling a bunch of weight with spacers doesn't put any more stress on the hubs than just having say a 4 inch offset rim bolted on??? Seems hard to believe, but I'm still curious
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 05-21-2012, 03:47 PM   #11
joe231
joe231's Avatar
You can speculate all day long...
But unless you have the engineering data they isn't proof either way.
All I know is my experience and lots of people that have used them with no problems...
CHEVY ONLY
Old 05-21-2012, 05:13 PM   #12
puppy
puppy's Avatar
Be very cautious of e-bay spacers. Some are cast aluminum. Some are true billet.
I always run a set from trailsport4x4(sscramblin???) on e-bay. I just got a set in Friday and they are beefy.
I have only ran them on the rear wheels of my 4x4's due to the 3" narrower rear axle housings.
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline   Reply With Quote
