Old 05-19-2012, 12:36 PM   #1
Mufrat62
Rallys-What year and makes to Use on '69 GMC
Does anyone know what year and makes of the Rally Rims will fit on my 1969 GMC 1/2 ton. It has drum brakes and the 6 lug pattern. I don't have enough cash to change to disc brakes right now and we just did the drum brakes.
Mufrat62 is offline   Reply With Quote
Old 05-19-2012, 02:03 PM   #2
dhughins
dhughins's Avatar
Re: Rallys-What year and makes to Use on '69 GMC
i believe they are 6 lugs on 5.5 inches. I just took 2 off the front of mine that were a "deepdish" . I went to 5 lug front disc. I found 2 5 lugs at the local junkyard for 50 bucks including 2 crummy centercaps. Hopefully they are only temporary til i can get the rear swapped to 5 lug.
i would try the local yards 1st. usually you can find them pretty cheap.
dhughins is offline   Reply With Quote
Old 05-19-2012, 07:23 PM   #3
Mufrat62
Dhughins-thanks for the reply. Do you know I'd there are many GM vehicles that had the 6 lug rally's ??
Old 05-19-2012, 07:29 PM   #4
dhughins
dhughins's Avatar
I honestly dont know. I was told on here that the fm vans came with the nondeepdish wheels, but we were talking about 5 lugs. Supposedly there are 3 different depths on the ralleys. Hopefully someone else will chime in, or try using the search for ralley/rally
Old 05-19-2012, 07:33 PM   #5
Dunenutt
Newbee
Dunenutt's Avatar
They are refered to as truck ralley's. Alot of 4x4 Chevy's had them in the 70's and 80's. I bought mine for $200 for 5 of them on Craigslist. I don't know if you have Craigslist up there though.
Dunenutt is offline   Reply With Quote
Old 05-19-2012, 08:12 PM   #6
Gene
Gene's Avatar
6 lug truck rallies are a little harder to find than the 5 lug, but they are out there and look great on these trucks.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-19-2012, 11:30 PM   #7
Mufrat62
Thanks for the replies folks, looks like I will start with the wrecking yards and go from there.
