Old 05-19-2012, 01:57 PM   #1
jrh55
Switch identification
Hello, just got my first full sized chevy since i had my 56. It is a 75 C20 Scottsdale. The electrical was a mess, got that mostly sorted, my ?????
there is a slide switch mounted to the steering column that interacts with the throttle linkage, what the heck is it called and what does it do?
thanks
jrh55 is offline   Reply With Quote
Old 05-19-2012, 02:55 PM   #2
beamn7
Re: Switch identification
Hey Neighbor! Welcome to the board!
Sounds like the kickdown switch used on trucks equipped with Turbo 400's
Does it look like this?
beamn7 is offline   Reply With Quote
Old 05-19-2012, 02:57 PM   #3
jrh55
Jesse, yep that is exactly what it looks like. None of my local parts companies can find that part in their listings
Old 05-19-2012, 03:21 PM   #4
beamn7
GM part number is 1242101. Most places should be able to cross that over or you can get online:
http://www.google.com/#hl=en&q=12421...w=1010&bih=531
Hope this helps
Old 05-19-2012, 03:30 PM   #5
beamn7
Be sure you adjust it too after you replace it. If I recall there is a button inside the shaft of the switch that will spring the switch towards the firewall. You then fully depress the accelerator pedal and it will self adjust the switch. The picture I posted is of one that has yet to be adjusted as the shaft is sprung all the way to the left. Once adjusted, it will be close to the center......give or take a little....
Old 05-19-2012, 04:09 PM   #6
jrh55
I can't thank you all enough, all i can say is thanks again
John
Old 05-19-2012, 10:11 PM   #7
crewcabsquared
They are still available GM also. Got mine from GM Parts East.
crewcabsquared is offline   Reply With Quote
Old 05-20-2012, 12:05 PM   #8
1977K10
1977K10's Avatar
LMC may have a part in their list too, there is a page of switches and such, my book is in my truck right now or I'd have a page for ya.
1977K10 is offline   Reply With Quote
Old 05-20-2012, 01:41 PM   #9
jrh55
Again my thanks for all the helpful replies. I was told by a hot rod shop that this switch is not needed, just power the solenoid and set it and i'd be good to go, not sure i want to go that route but i may
thanks
john
