help with fuel filler
Help please,
I have relocated the tank to spare tire location. I need a creative solution to the filler neck and cap which is currently flopping around in the hole cut in the bed. (rear drivers side at inside corner of wheel well) I need a several inches so fuel doesnt splash back from the elbow when fillling..Im thinking a custom box of some sort, or if anyone has found a filler door, cap, neck combo that would work I'd love to see what you have done. 1972 Highlander...thanks in advance!: |
![]() Join Date: Jul 2007
Re: help with fuel filler
I had a buddy make a box that I put the stock rubber grommet in and the neck through. like stock. The top of it was at a 45 degree angle and the box was like 5'' square. I don't have any pics sorry. I liked it but I added a vinyl bed cover w/ aluminum frame and snaps. I didn't like un snapping it every time I filled up.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
Find yourself a donor, late 80's chevy pick up or suburban, and scavenge the fuel door, hose and vent hose. They fit perfectly. Easy peazy...
Has more rust than truck...
Hart_Rod's idea...
http://67-72chevytrucks.com/vboard/s...el+filler+idea I kinda used his idea. http://67-72chevytrucks.com/vboard/s...382181&page=20 |
I used a 45 degree marine filler neck and made a little enclosure for it tucked just inside the bed.
"Negative people always seem to have a problem for every solution" |
This is mine. Put it behind the backup light. It works great and have no problems filling.
My tank and filler are from an 80's Blazer. Think the cover/wedge came from the same rig. I cut it in half width wise and added about an extra 2-3 inches to extend it after I welded in the mid 90's Chevy fuel door. Filler hose fits nicely between the frame and bottom of the bed.
Check out the project silver dollar build. mrhino had a pretty discreet option for a filler. I also did this on mine and I like how it looks, although I think I need to play around with the slope of the lines as it is slow filling.
Tags |
please help |
