Old 05-19-2012, 08:56 PM   #1
medicman775
new gas tank install
Bought a new tank...how do you remove filler neck from stock tank? Removed the 2 nuts but now what/how? I'm referring to the piece that is attached to tank that is different on the replacement tanks.
medicman775 is offline   Reply With Quote
Old 05-19-2012, 10:51 PM   #2
niceguy678us
Re: new gas tank install
You have to bring it to a radiator shop and get them to un-solder the neck from your old tank, un-solder the neck from the new tank, and re-solder the old neck to the new tank.
I got my radiator shop to coat the inside while they were at it.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
Old 05-19-2012, 11:04 PM   #3
medicman775
Thanx
Old 05-22-2012, 02:41 PM   #4
72blazerblue
72blazerblue's Avatar
what is wrong with the necks on the new tanks?
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
72blazerblue is offline   Reply With Quote
Old 05-22-2012, 03:56 PM   #5
1949gmc
new tanks don't have the long curved neck like the old tanks... they just have a short little stub. original neck goes around the one body mount, short and stubby goes right into it. some folks have tried a rubber hose to go around the mount, but it tends to kink... not good having a kink in your hose.
1949gmc is offline   Reply With Quote
Old 05-22-2012, 04:09 PM   #6
72blazerblue
Hmm.. that must mean the old rusty one I pulled off mine was not original. It had a stub. Just like the new one I got. They had a tube coming off the stub to a curved metal peice and then rubber hose going to bed side filler. Think I will just put it back like that!
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
Old 05-22-2012, 04:46 PM   #7
1949gmc
Definitely, if it worked... don't mess with it.
Old 05-22-2012, 04:49 PM   #8
72blazerblue
Yes, i agree. It may be a better solution for those going the soldering route, to just cut off your existing neck and connect it with your hose to you new tank! Looks like what was probably done to mine.
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
Old 05-22-2012, 04:54 PM   #9
1949gmc
Here are a couple of pics that I borrowed from herb101's thread on replacement tanks.
Original neck
New neck
Doesn't quite make it
Old 05-26-2012, 02:37 AM   #10
ajax_mp
Instead of soldering it, just cut the neck off the old one and trim down the new one, and just cut about a 1-2" hose section and use two clamps to combine the two pieces.
Works fine , havent had any problems.
ajax_mp is offline   Reply With Quote
Old 05-26-2012, 06:12 PM   #11
medicman775
Good idea ajax...wish I would have thought of that before I had a shop swap necks.
