![]() Join Date: Jan 2012
bench to buckets
I have a 1988 1 ton suburban that has a bench seat in it . what would i need to convert it to buckets with a console . I have a set of buckets out of a blazer but they dont even look close to fitting .
Garage wrench
Re: bench to buckets
you would need the seat base brackets and inner seat base to floor bracket that is welded to the floor on the suburbans. You're best bet is to find one at a salvage yard and take all you can from it.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Getting Old; Going Broke
Suburban and truck floors are totally different than the K5's floor. K5 has a flat floor and sub/truck has a huge hump that the seat sits on.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
78K & 79C Jimmys
i did 89 burb to 78 jimmy
had to drill my own holes in the seat base but with the right bases it worked
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
