Old 05-20-2012, 11:31 AM   #1
gag1025
Radiator Fan Placement Question
I am going to replace the fan blade on my '53 Chevy truck with an electric one. Is it more efficient to use one that mounts in front that pushes the air through or one that mounts behind that pulls the air through?
gag1025 is offline   Reply With Quote
Old 05-20-2012, 11:36 AM   #2
Rude Dude
Rude Dude's Avatar
Re: Radiator Fan Placement Question
Either works but if you look at all the factory ones they are mostly pull they are engineered for effiency and all the guess work is taken out of the equation that is why I went with pull type.
Rude Dude is offline   Reply With Quote
Old 05-20-2012, 12:23 PM   #3
Daze57
Daze57's Avatar
x 2 ^
Daze57 is offline   Reply With Quote
Old 05-20-2012, 06:06 PM   #4
gag1025
I figured that all the car companies used the pull type because there is more room in back than in front. I was wondering if anyone had done any research into this. Perhaps had one hooked up behind and then in front and checked the amount of air flow for each position.
Old 05-20-2012, 06:23 PM   #5
OrrieG
OrrieG's Avatar
GM spends millions on engineering for the most efficient and elegant design solutions. If you have the room use a puller fan.
OrrieG is offline   Reply With Quote
Old 05-20-2012, 07:25 PM   #6
_Ogre
_Ogre's Avatar
there's more room in back because they are designed that way.
like orrieg says, they spend big bucks on engineering,
if they could put a pusher and a smaller radiator in to save $1 per car
they would
shop air compressor timer
Old 05-20-2012, 07:41 PM   #7
GMtrucknut!!
GMtrucknut!!'s Avatar
The fans are designed to use the natural flow of air pushing through as you move and the fan helps cool by pulling at low speeds.
GMtrucknut!! is offline   Reply With Quote
Old 05-21-2012, 12:11 AM   #8
parkwood
parkwood's Avatar
If i can put my two cents in on this... try www.coolingcomponents.com they make a fan to fit all most everything and they come with a built on fan shroud which helps a ton pulling the air thru the radiator.. the picture i have here isn't a cooling components one but they look just like this one.. they are only 2 5/8" thick which should clear everything..
parkwood is offline   Reply With Quote
Old 05-21-2012, 08:06 AM   #9
LDO
LDO's Avatar
Parkwood,
your link led me to an industrial cooling tower mfr, (that would surely cool our engines though! ).
Did you mean these guys instead?
http://www.coolingcomponentsinc.us.com/index.html
LDO is offline   Reply With Quote
Old 05-21-2012, 11:14 AM   #10
solidaxel
solidaxel's Avatar
That works for me here in the "dry" heat !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-21-2012, 12:32 PM   #11
parkwood
parkwood's Avatar
Originally Posted by LDO View Post
Parkwood,
Sorry about that, yes the cooling tower would work great but you would have to have a water truck follow you around all the time...
I was helping youngrodder with his over heating problems and just got an email from him this morning saying that he call cooling components and they gave him great help in picking out a fan for his truck...
Hope they can do the same for you if you call...
Old 05-21-2012, 01:12 PM   #12
youngrodder
youngrodder's Avatar
I agree with the plug for Cooling Components (CC). I have been fighting an over heating problem for a while now. My current set up is one cheap 16" EBay pusher fan (Huston we have a problem). At the request of a friend, I called CC today and they were very helpful. Since my set up is not factory as far as the dimesions of my radiator as well as the location of the hoses, I was skeptical that they could help. Boy was I wrong. I now am on the right track. I would rather spend decent money once and be done with it. CC's fans are also (2) speed. I didn't know this until I talked with them.
One thing that they told me that stands out is that when pushing air through a radiator you loose approximaly 50% of the CFM's. Good to know.
Keep cool
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-21-2012, 01:40 PM   #13
Maximus
Maximus's Avatar
as mentioned, most fans are designed to pull, one of the big reasons for this is with a pusher fan your fan is blocking the front of the radiator from natural air, i think this was mentioned above... thus putting the fan on the rear of the radiator your fan can work, as well as the laws of physics when your moving forward with the natural air... I just made a flat mounting bracket out of sheet metal and mounted mine on the back of the radiator.
Maximus is offline   Reply With Quote
Old 05-21-2012, 07:59 PM   #14
LDO
LDO's Avatar
Yep, I will be giving them a call.
Old 05-21-2012, 11:36 PM   #15
mknittle
mknittle's Avatar
that is what I was thinking.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
