Old 05-20-2012, 02:07 PM   #1
po_bird
po_bird's Avatar
How do i fix a loose steering wheel
Took the steering wheel off my 75 to swap the turn sig cam and now its loose and i cant get it back to how it was. Anyone know how i can fix it?
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
Old 05-20-2012, 02:13 PM   #2
deth_1970
deth_1970's Avatar
Re: How do i fix a loose steering wheel
is it tilt steering?
and hello from Braggs
78 dualy crew cab wife calls "the beast"
79 silverado "yeller"
99 tahoe
02 Gmc sierra
deth_1970 is offline   Reply With Quote
Old 05-20-2012, 02:21 PM   #3
po_bird
po_bird's Avatar
It is tilt. Hows it going neighbor
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 05-20-2012, 05:18 PM   #4
deth_1970
deth_1970's Avatar
is it loose at the tilt knuckle?
not too bad, getting a set of headers on my truck
99 tahoe
02 Gmc sierra
Old 05-21-2012, 12:58 AM   #5
po_bird
po_bird's Avatar
No. Its loose right at the bolt the holds down the steering wheel.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 05-21-2012, 02:17 AM   #6
Mrknowitall
u mean u can pull it in and out?? that kinda loose? or do u mean like if a buddy was holding the wheels keeping them from moving, but still moves left and right as if turning???
obvious: did u remember the spring? did the o clip that keeps the spring in fall out/break?
not obvious: is the rag joint installed properly? if its the orij. rag joint, its found home and needs to be put back into orij position/replaced.
Mrknowitall is offline   Reply With Quote
Old 05-21-2012, 10:56 PM   #7
po_bird
po_bird's Avatar
Its more like a wooble loose. If thats a word. Haha... I think its the race that goes over the upper spindle bearing. But im not sure how to seat it back down over it. The spring and clip are in.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 05-21-2012, 11:02 PM   #8
mattpiotr
just a suggestion i had a similar problem on my 87 1 ton 4x4 dump the steering wheel was always loose and it was the steering coupling gasket that round part that connects to the gear box was bad
mattpiotr is offline   Reply With Quote
Old 05-21-2012, 11:16 PM   #9
po_bird
po_bird's Avatar
The wheels dont have any play in them. Just the steering wheel.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 05-22-2012, 12:53 AM   #10
Mrknowitall
The rag joint.
Well idk sir, u took it apart and now its broke, retrace ur steps, cant helLp ya without more descriptions. Check what i said. Take some pics showing play, make a video.
Left to right play can be a bearing or rag joint, good luck. Retrace ur steps, the problems gonna b obvious just gotta stare at it long enough.
Make a video thats ur best luch
Old 05-22-2012, 12:54 AM   #11
Mrknowitall
The rag joint.
Old 05-22-2012, 07:32 AM   #12
rs72z
rs72z's Avatar
Very possible that you lost some or all of the bearings in the upper bearing below where the spring is at. The seat that that the spring sits on holds the upper bearing in place.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
