Old 05-20-2012, 02:42 PM   #1
csa daddy
csa daddy's Avatar
Removing lower kingpin bushing from dana60 help please
I need some help to figure out how to remove the lower bushings for a Dana 60 for the lower king pin I've looked all around an cant find a answer any help would be great . Do I need to just drive it out with a punch or what
csa daddy is offline   Reply With Quote
Old 05-20-2012, 03:35 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Removing lower kingpin bushing from dana60 help please
The bottom plate is bolted to the bottom of the knuckle and the bearing rides on a race pressed into the bottom of the inner C. One of mine came out with a punch from the top (sheetmetal cover got dinged up, oh well) and the other one I had to weld a bead inside to shrink it then it popped out with a few blows.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 05-20-2012, 03:45 PM   #3
csa daddy
csa daddy's Avatar
Ok Thanks I tried to knock it out the other day didn't seem to want to move will try a better drift or chisel or something an continue to beat on it thanks again won't sure if that was the best way to get it out or if there was something easier
Old 05-20-2012, 07:31 PM   #4
mknittle
mknittle's Avatar
good method! I havent done that But I have welded a round piece itto a race so I could get a big punch on it.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-20-2012, 08:05 PM   #5
csa daddy
csa daddy's Avatar
That don't sound to bad either if the other fails I will do that next
