05-20-2012, 02:48 PM | #1 |
6.0 LQ4 Drive by cable
Im getting ready to install the 6.0 engine into the 71 and just realized its a drive by cable. To be honest, I never payed much attention as I was planning to do a carbed set-up at the time. But after month's of reading, I realized I'd be a fool to not run the fuel injection. Unfortuanetly I wasn't aware that I needed the gas pedal and tac module when I got the engine.
Has anyone just used the stock pedal assembly? I realize the drive by wire is an easier set-up for cruise control, but cruise is not that important at this time, and I dont want to change intakes. Any help appreciated |
05-20-2012, 05:05 PM | #2 |
c10 Chop Artist
Re: 6.0 LQ4 Drive by cable
You can use a cable actuated throttle but you have to change the t-body. If you keep the drive by wire you have to get the electronic pedal. There is also a short dedicated wire harness that goes from the pedal to the electronic t-body.
65 c10 build http://67-72chevytrucks.com/vboard/s...d.php?t=467433 68 c10 on 22's (sold it) http://67-72chevytrucks.com/vboard/s...d.php?t=303594 |
05-20-2012, 06:41 PM | #3 |
If you keep the drive by wire, you have cruise control built into the tac module and all that would be missing is the cruise wiring. That would be a plus
