Old 05-20-2012, 05:30 PM   #1
airbrushguy
1967-72 Brake booster
I have a '71 C10 with manual disc brakes in front/ drum rear. A friend offered to sell me a brand new booster from a '70 C10 he sold that had drums all around.
Can I use it and if so, what type of MC and propporiotning valve do I need.
airbrushguy is offline   Reply With Quote
Old 05-21-2012, 02:40 AM   #2
Bob B.
Re: 1967-72 Brake booster
'67-'70 drum brake trucks use a Bendix booster, '71-'72 disc brake trucks use a Delco Moraine booster. They do not interchange, the brackets and master cylinder is different.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 05-21-2012, 09:10 AM   #3
68gmsee
Active Member
68gmsee's Avatar
hmmm.. I do believe it will work. I'm pretty sure I've used boosters from different years on my trucks and they all fit.
You can use your own master cylinder and proportioning valve but will need all of the extra stuff like booster bracket and linkage. Hopefully he kept everything from the brake pedal pushrod forward otherwise you will have to look for those parts.
Move the m. c. forward as far as you can without over stretching the lines to get the bracket mounted.
68gmsee is offline   Reply With Quote
Old 05-21-2012, 01:51 PM   #4
camaney
I just use one from a 72disc to gmc 67 drums
camaney is offline   Reply With Quote
Old 05-21-2012, 04:25 PM   #5
airbrushguy
OK....consensus of opinion is I might be able to use a ('67-"72 drum brake booster) on a '71 disc/drum car..?? Right?
Can I then use my new manual MC with it or do I need to get a MC made for Power Brakes?
Is the proportioning valve different for a PB setup than a manual?
Thanks for all your help.
Old 05-21-2012, 04:48 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Yes, you can use your master cylinder and prop valve. The only thing the brake booster does is assist in the braking. Everything else other than mounting brackets and brake pedal link is the same.
Old 05-22-2012, 08:46 AM   #7
airbrushguy
Thanks alot...what's different about the pedal link?
