Fusible link on 65 c10 from battery?
I had to replace the red wire running from the positive battery post to the junction ( horn relay) just before the voltage regulator. In my diagram in the repair manual it does not show a fusible link near the battery.. nor was there one prior to me rewiring. Yet I see many threads speaking of one near the battery in the red wire. Was this something added on 67 and later c10's? I'll try and post the diagram to show what I refer to.. I see on previous threads diagrams posted with one installed.. I'm confused...
Also the original diagram for the 6 cylinder (In my manual not the same as posted) showed a red #12 wire battery to horn junction. I since upgraded to a small block 327 so I upped the wire to #10. Does that seem plausible? |
![]() Join Date: Feb 2010
Re: Fusible link on 65 c10 from battery?
As far as i know fusible links werent until the 70's. Neither of mine have them. And mine are original still.
![]() Join Date: Sep 2011
None of my 62-66 trucks had them. I sure don't think it would hurt to add 1.
I always do when I wire up for a 2-way radio, either CB or HAM. I always power straight off of the battery with a fuse as near to the battery as I can get.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
