![]() Join Date: Oct 2009
Who makes a GOOD hood hinge??
Ok when I built my truck 22 years ago it needed the hood hinges replaced so I bought a pair of aftermarket hinges. After using them for 20 years I noticed the hood was not closing correctly and the hinges were coming apart. I was changing the engine and had the hood off so I thought it would be a good time to replace them. Because of this web site I found out that GM still sold the hinges thru the dealer. Getting the part numbers from this great site I ordered 2 new hinges from the GM dealer. Now less than 2 years later I went to a cruise in and lift the hood and the right side hinge comes apart. One of the pivot pins falls apart. So between it coming apart and having to get the hood closed to drive home, the hood paint and cowl paint is chipped, inner fender is dented and scratched. I check the left side and found that it is leaning bad and looks like it is about to come apart at the same pivot. So I now have 2 loose and rusted hood hinges on the truck so that I can open the hood. I need new hood hinges and trying to figure out where to buy from. Any suggestions?? Brand? Supplier? I guess I should have bought cheap junk instead of expense GM junk. Thanks for any suggestions.
If this is not in the correct area feel free to move it.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
Re: Who makes a GOOD hood hinge??
Post a want to buy ad in the classified and get a good set of OEM used hinges. They are plentiful and fit properly. I have yet to find ANY aftermarket parts that fit and function properly.
Porterbuilt makes hinges, but they are not a bolt on affair, they do require some cutting and welding, but they look great.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#4 | ||
Has anybody used the ones from GMCPauls ?
There is company out there that rebuilds them with oversize rivets correctly. I have not personally used them but one of the board vendors recommended them once before as being a top notch repair. Might consider them over buying worn out or repops. Check the archives on hinges should be there under one of the responses. 20 years on a set isn't bad if they lasted that long is it?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Moderator
![]() Join Date: May 2007
Board member Sinister used a set from LMC. Said they were made in Argentina of all places! Also said they fit and work perfectly. I was very suprised to hear this, as most of LMC stuff is junk. There was a thread on here a few days ago where a board member bought NOS GM hood hinges and said they were loose as well...looks like they are one OEM part to stay away from now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Nov 2007
Might not be a bad idea to get an original set and send them off to www.hoodhingerepair.com for rebuilding. plenty of the chevelle guys have used them with good results.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#9 | |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#10 | |
Shortbed club member
omg...$600
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
#11 | |||||
They do look nice but more than I would want to pay.
![]() Join Date: Feb 2010
Ever find out the price to rebuild the hinges?
#13 |
General Motors
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#14 |
I got a quote a while back. I forgot what they priced it out to me for, so I emailed them again asking, plus I need to see if they can repair one because I had the main pivot point bust a rivet. Been using a bolt thru it since then. But I am still thinking about going with Porter's hinges. They look great and I have heard nothing but greatness about them. Wife might kick my butt for spending the money, but I won't have to worry about them wearing out on me. Plus, one off the nuts that was tacked on for the bolt to run thru was busted off. PO must have put the wrong bolt thru. It was a PITA to get a nut back there at tighten it up.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
#15 | |
I have not checked. I just stuck a pair of used ones on for now and was going to do something this winter.
I tried them and they lasted 2 years and fell apart. I bought them straight from the GM dealer 2 years ago. Quote:
#16 |
They have good customer support. Just got an email back from the above mentioned people that rebuilds them.
Thank you for the question Joseph, We can rebuild your hood hinge set for 150.00, plus shipping charges. That gets them back to you in bare metal or in primer with 14 new rivets, lubed with white lithium grease in between all metal to metal movement areas and under the rivets, when pressed into place. We can look at the part that has the bolt in it and repair that or replace it with a core part off our shelf, to make sure your hinges work smooth and easy when you get them back. We offer a few coating options as well if you are interested. We offer a Zinc Phosphate spray finish, which is featured in our video for 20.00 additional dollars for your hinges and springs. We offer a cast blast spray finish, if you like a lighter grey finish for the same price. We also offer a powder coat for 75.00 additional dollars in any color you like from the Eastwood catalog or from their website color chart at www.eastwood.com. We accept checks, money orders and credit cards transacted through PayPal only. If sending payment with the hinge set, please add the additional amount you paid in shipping, to the check. I tell everyone to get a quote from their shipping source, prior to sealing the carton, then drop payment inside, tape them up and ship them to us. Also include a note with what you need done, a return shipping address, a contact phone number and a e-mail address, so we can send you a tracking number or PayPal invoice, if you choose that route of payment when work is completed. Most all work is done and returned within 7-10 working days of received payment. If you have further questions, please just e-mail me back or just call us. Thank you again and I hope we can rebuild those hinges for you. Willie Wilson Wilson Antique Car Parts 1067 Clearview Drive Forest, VA 24551 434-258-2606
#17 |
Emailed Willie back, telling him I would have to wait till I got back to the states from here in Afghanistan. Promptly got a return email thanking me for my service and hopes for a safe return. On top of that offered me a free coating of my choice and free return shipping.
Making my decision making process a little harder on me. Save a little cash to spend on something else for the truck, or go all out and go with Porterbuilt. Guess I will have to way the options and see where it takes me. I would recommend these guy's already just by customer support.
#18 |
Old member
I just bought a set of the chrome powder coated hinges from Wille. Great guy and fast shipping less than 2 days to my door for free.
$210.00 no exchange. They are wonderful. The hood shuts just like it did new. They are wonderful. U want be sorry with these hinges. I promise. ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#19 |
Awesome deal. Glad we have someone to testify to the work. Looks great.
#20 | |
Old member
![]() Quote:
Yes they do and I'm not even a payed advertiser for him! ![]() ![]() ![]() ![]() ![]()
#21 |
It would save me some money and work for sure. Especially with the deal he is willing to give me. But still, there is something drawing to the PorterBuilt ones. Hard decisions! If they would cut me a deal, I would be having some real hard decisions to think about then....lol
Good thing I have several months to think about this. By then, the money will probably be spent on the little things I will run into and be buying Willie's for sure. Either way I see a win win situation in the future.
#22 |
Moderator
I would go with Porterbuilts, or just rebuild my own.
#23 |
Yeah, I will see when I get to that point. I do tell you one thing I never want to hear again, and that's the big boom sound one makes when the main rivet bust....lol If the truck had been running, I would have thought something had went seriously wrong.
#24 |
Old member
Those are some very nice hinges for sure. If my truck was a complete show truck and I had the money to throw into it I would have bought theirs but for a driver I just can't justify the money.
For the price of the hinges form Willie I doubt you could rebuild them and get them powder coated any cheaper. I also called 2 Chevy dealers in my area neither one of them would even try to look up the hinges. If I remember right Willie told me as long as I owned the truck he would stand behind the hinges. So if one fails it's replaced. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-16-2012 at 10:29 PM. |
#25 | |
Moderator
