Brought the 65 home yesterday, what a weekend
SO I finally brought my truck home from storage but what a test. It took 15 minutes of cranking to get it started and when I did fuel was pouring out of the cracked gas line in 4 places. Went and got a new line and fixed that, pumped up a tire and drove to a gas station, the gas attendant pulled the gas cap off and the filler neck came with it,LOL. Had to replace the 2 quarts of tranny fluid that had leaked out and stop the slipping. and made it home. No signals or brake lights worked so I started on it today and fixed the fuel filler neck, no hose clamp, took off a dana cruise control setup as the wiring under the dash was terrible, pulled off the wheel, fixed the signals and brake lights and sorted all the wiring out, threw the aftermarket radio away and cleaned everything up. Changed the wheels as one didn't hold air and I had a set laying around from another truck and changed the air filter and hooked the kick down linkage up.And to top off the day , my transmission in my Yukon XL packed it in on the way home and the fluid is burnt bad, I had to cruise home at 15 miles an hour or it wouldn't move. So now I have another project to do, one which can't wait because the wife drives it. Off to Ebay to find a 4L60E.
PS, this truck on the build sheet has 4N01AA 20 gallon gas tanks. Do you think the tanks hanging down are them or aftermarket. I would like to remove them but if it was factory I will leave them, nothing like having 60 gallons of gas erupt if you get hit. |
Re: Brought the 65 home yesterday, what a weekend
very nice !!!
nice rig!
Looking good man,same color mine was before I tore it down
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4 |
65 suburban vortec 5.3 bagged
wow that looks like it is nice and solid!!!
great looking truck
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Looks to good to have any issues mine is horrid and everything works! Even the map light. Good body on her tho
My first ever build!! 1965 c10 LWB 283v8 sm420 http://67-72chevytrucks.com/vboard/s...63#post5337863 |
![]() Join Date: Feb 2003
very kool.......
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
![]() Join Date: Nov 2008
You sure end up with alot of trucks having Factory A/C ...
Garage wrench
A side note for you.....gm has a $200 rebate in the form of a gift card on their remanufactured transmissions right now. Anything 2006 or older qualifies. That and a 3year/100K mile warranty if your local dealer installs it. Just a heads up for you.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Thanks, I will look into it , I called them today but haven't heard back fromm them.
![]() Join Date: May 2007
Wow what a great start
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
