05-20-2012, 10:28 PM | #1 |
Coil Question
Hey guys did a tune up on my truck yesterday new plugs, wires etc. noticed a wire loose beside the ignition coil. fastened to the side of the bracket that bolts the coil to the engine block is a small device that looks similar to a condensor. it has a single wire coming out the top of it that attaches to the (+) side of the coil. that wire broke off. trying to find out what that piece is, I thought it was some sort of resistor but cant find a part that looks like it anywhere or in any diagrams that i have. is it a necessary part any thoughts?
05-20-2012, 10:41 PM | #2 |
Re: Coil Question
It keeps the static out of the am radio
05-20-2012, 10:44 PM | #3 |
Re: Coil Question
It's a capacitor used as an ignition noise supressor.
Keeps you from hearing the sparkplugs firing in your radio. Not needed if you don't have a radio. Mike. |
05-21-2012, 12:52 PM | #4 |
Re: Coil Question
Hey thanks guys i thought that might be a possibility but wasnt sure. I had read somethings about a resistor that would drop the voltage from 12 to 8 or 9 to prevent pre-mature burning of the points and just wanted to make sure this wasnt one of those.
05-21-2012, 09:43 PM | #5 |
Re: Coil Question
I think you are refering to whats called a resistance wire. Im not an electrician, but i think that a resistance wire is a different size wire diameter. Not sure tho.
