hometown heroes!
flip-kit questions
My truck has been lowered the wrong way. The rear-end has just had some leafs removed, leaving the longest and shortest. How hard is a flip kit to install? How much do they run? Whats a good brand to buy? Will my truck be about the same height?(Right now the top of my 275/60s are barely hidden by the fender wells.) Can I use stock springs from a salvage yard truck? (breathe Wes...)
I can't stand the bounce or the bumpstops smacking the rear axle. Also, I get lots of torque twist at the rear joint cause the leafs offer no support when I get on it. ![]()
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th... ![]() Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee "Never give up ground you've already taken." -Unknown |
i got a flip and it will lower the back of your truck abour 5-6 inches so if ites in the fender now it will rub later. i made my own srping handers out of 1/4 inch cold rolled steel and wilded it to the housing. ill post a pic.
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
2
