Old 05-21-2012, 02:34 PM   #1
70sarver
70sarver's Avatar
Hood latch problem
I have a 1970 w/hood latch issues. It will not pop up when released. I also have some hood adjusments to do, but I do not think this is related. Has anyone else had this problem? Any help would be appreciated.
70sarver is offline   Reply With Quote
Old 05-21-2012, 04:37 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Hood latch problem
The hood adjustment could have an effect on the latch, it should be adjusted first. If the hood is causing the pin not to be in the center of the latch it may be dragging and therefor hard to release.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 05-21-2012, 05:35 PM   #3
cdowns
cdowns's Avatar
i find cleaning and lubricating 40year old moving parts helps them work better
Old 05-21-2012, 05:57 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes -- besides the latch, lube all the joints in the hinges too.
The hood latch spring isn't missing.... right?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-22-2012, 09:32 AM   #5
70sarver
70sarver's Avatar
No spring is there. Just wondering if hinges can just wear out?
Old 05-22-2012, 10:04 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes, they can.... but if the latch on your '70 is anything like my '72, the spring is what gives the hood that initial push upward when you release the latch.
Can someone with a '69 or '70 verify whether the hood latch is supposed to have a spring?
- Mike -
RIP El Jay
Old 05-22-2012, 10:54 AM   #7
cdowns
cdowns's Avatar
are you saying there is not a spring there?
OR
are you saying no the spring is there??
Old 05-22-2012, 06:09 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ Good catch, Cliff. I'm a literal person, so I read it just as he wrote it -- "no spring is there".
Never realized he may have intended to say "no, the spring is there".
Guess we'll find out in time.....
- Mike -
RIP El Jay
Old 05-22-2012, 06:24 PM   #9
racer57
racer57's Avatar
Curious about this also. My 71 does not have a spring on the hood latch mechanism and wondered if it was supposed to have one
racer57 is offline   Reply With Quote
Old 05-23-2012, 09:53 AM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Guys, I apologize -- my memory has failed me again, I could have sworn there was a spring (actually, I thought it was attached to the hood, where it contacts the latch). Anyway, I just looked and the only springs (that lift the hood) are on the hood hinges.
So, to 70sarver -- maybe your hood hinge springs are weakened -- but as said, first try lubing every moving part on each hinge.
- Mike -
RIP El Jay
Old 05-23-2012, 10:22 AM   #11
MrSchaeferPants
MrSchaeferPants's Avatar
Does it not open, or not 'pop up' ? If it doesn't budge, I'd say adjustment, the latch might not be clearing the plate on the hood. If it doesn't pop up, but you can still lift it no problem, perhaps your springs are worn out. Adjust, clean, and lube. If the hood is aligned pretty good, both the latch plate on the grill/core support, and the plate on the hood do adjust a bit, don't forget the pin can be adjusted up/down as well, just a screw and jamb nut, oh and also, the pads near the fenders on the core support adjust up/down as well, same thing screw w/jamb nut. If those two pads are adjusted too high it'll cause problems as well.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
