Old 05-13-2003, 10:18 AM   #1
justjimsgirl
Question What to use?
I've been told so many thing's. What transmision should I use? 402 BB W/ Offenhauser tunnel ram W/dual Holley 550 D-pumpers. Rearend is 12 bolt with 4-11 gear's. I have a turbo 400, but I think It need's another gear? maybe a 700R4?
justjimsgirl is offline   Reply With Quote
Old 05-13-2003, 10:22 AM   #2
case_bt
case_bt's Avatar
to make it more streetable I'd go with the 700r4
case_bt is offline   Reply With Quote
Old 05-13-2003, 10:29 AM   #3
justjimsgirl
Thank's, should I change to a bigger cam also? (to help the tunnel ram work to peak performance), That's what I was told.
Trying to make a buck,
so I can finish my 72 truck.
09/11/72, than and now!
Old 05-13-2003, 10:35 AM   #4
doug72
I am going to use a 700R4 in mine, just because I have it and it is already built. If I was starting again, I would use a 2004R from Phoenix transmissions. They hold more HP than the 700R4 and have a better shift pattern. I have one in my Rs/SS 69 Camaro. I am going to use one behind my LS6 454.
Doug
doug72 is offline   Reply With Quote
Old 05-13-2003, 11:11 AM   #5
neonlarry
neonlarry's Avatar
That sounds like a pretty healthy engine, and either a 700r4 or a 2004r will take a bit of work to handle that much power. I would go with a 2004r though if you want overdrive. What cam does it have in it now? And what sompression ratio? That would help with deciding what cam would be best to use in it.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-13-2003, 11:24 AM   #6
gr8scott51
gr8scott51's Avatar
The Copperhead project on Trucks! TV show used a 400 behind the 572. The 400 is much stronger. He added an aftermarket overdrive to the tailshaft on the 400. That essentially gave him 6 gears. That should be plenty. Good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 05-13-2003, 08:22 PM   #7
crazy longhorn
Fabricate till you "puke"
I 2nd that......400 turbo, with a gearvendors OD unit on the back would be the ticket to many happy miles of abuse.....er I mean fun crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-13-2003, 09:03 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And here is the link to there site. http://www.gearvendors.com/commercial.html
If you have the cash, the gear vendors (or another brand) is the way to go.
