Old 05-21-2012, 09:26 PM   #1
54hydramaticFL
54 disc brake conversion
I'm converting my 54 Chevy 1/2 ton to 6 lug discs in front. Also using 2.5" drop springs in front and 3" in rear. I understand my stock rims won't fit. I read somewhere that later model chevy 6 lug rims will. I can't seem to find the post with that info and was hoping someone here might help. Also considering going to 16". Any thoughts? Thanks.
54hydramaticFL is offline   Reply With Quote
Old 05-22-2012, 09:11 PM   #2
yossarian19
Re: 54 disc brake conversion
Stock rims might or might not, from my reading. Assuming they won't, you can run any Chevy or Toyota 6 lug rim as they are all 6x5.5"
A 16 or 17" rim should clear any aftermarket kit you can dig up for the stock front axle or most anything else. Note that 16" aluminum rims might not have a *ton* more clearance than 15" steelies, but still should clear.
I don't know about back space but from what I have seen, back space measurements on OE wheels from vehicles of a similar type will be the same or darn close.
In short: pick out some 6-lug Chevy or Toyota wheels you like at the junk yard & enjoy. Just try to pick a tire with the same external diameter so you don't throw your speedometer too far off when you switch rim sizes.
yossarian19 is offline   Reply With Quote
