Old 05-22-2012, 02:01 AM   #1
ABX131
ABX131's Avatar
I saw it on Ebay and wondered???
I saw someone selling a full dash unit for my 63' and it got me to thinking how difficult is it to remove the one in my truck? mine does need some work and prep and it looks like removing it (or the windshield) would be a lot easier than working on it in the truck....Has anyone done this?
ABX131 is offline   Reply With Quote
Old 05-22-2012, 08:37 AM   #2
awbrown
Re: I saw it on Ebay and wondered???
If I get a chance i will post some pictures of the attachment points for it ,I just sold one a while ago I did not drill out all the spot welds I simply cut it out on the front side ... the hardest part is behind the inner dogleg ,the first panel towards the door from the dash , covers where it is spotwelded ... might be easier to remove 2 inches of that so you have access to dril out those welds ...
awbrown is offline   Reply With Quote
Old 05-22-2012, 09:18 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Post #3 on the following thread has a link showing the spot weld areas under the windshield:
http://67-72chevytrucks.com/vboard/s...=removing+dash
And post #6 indicates where the others are at the ends of the dash.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-22-2012, 09:21 AM   #4
1963c-10
1963c-10's Avatar
Cool thread, Im fixing to remove one from my parts truck and was wondering how much of a PITA it was going to be. The rest of the truck has been disassembled and I figured somebody might be able to use it. I have removed the bolts, but hadn't gotten to the spot welds yet.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-22-2012, 10:35 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
It took me a whole weekend to carefully remove this from a friend's '62. Air chisel, regular chisel/hammer, and an angle grinder.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
