Speedo help
Iv'e just changed from stock wheels and tires to 20" rims with 35 profile tires, It's has 3.44 gears and a T350, The Speedo is out about 20 MPH , It has a Red Speedo Gear Any one know which color I should have?
#2 | |
Re: Speedo help
Re: Speedo help
No good, carn't load in 20" , The 20 MPH is fast
Re: Speedo help
hummm.... then idk, someone here years ago had a chart that converted rim size to 15in rim with tire size to equal 20's but i cant find it...... wait till tomoro when everyone is awakle im sure ull get ur answer, alot of guys run 20s here.
sorry! |
Re: Speedo help
Great , thanks
Posted via Mobile Device |
Re: Speedo help
I'd figure out how much you are off, in percentage (by pacing with a GPS) and then throw an external adapter on there -
http://www.partshp.com/speedometer_gears.htm K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Moderator
![]() Join Date: Oct 2008
Re: Speedo help
Try this Excel 2003 Spreadsheet. It calculates RPM and Speedometer gear information including ratio adapters based on transmission, Transfer Case, axle ratio, & tire sizes.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
BAD BOW-Silverado XST
Re: Speedo help
Plug your info into this calculator. http://www.tciauto.com/tc/speedometer-gear-calculator
Change the drive and driven gear ratio until you find a combo to the closest whole number. You may have to change the housing if you change the driven gear too much. |
