Routing fuel lines
Looking for suggestions or tips on how you are routing your fuel lines. I am going to run the nylon tubing and have my fuel tank under the bed. I also have a 9" step notch. I have to fit the pump and filter on the frame rail, but don't see a way to mount the pump below the tank since I have to route the lines over the notch.
Posted via Mobile Device |
Truck and auto performance nut
Re: Routing fuel lines
mine are mounted just below the top of the tank along the frame rail. I don't have a notch but I'd think as long as its on the other (high pressure) side of the pump you'll be OK. I used all 3/8" s.s. hose and AN fittings for attachment. Corvette regulator is on the inside of the frame rail and provides the short return back to the tank.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#3 | |
Perfect! I have a similar tank, so I know what to do now! Is that a filter before the pump too? Guess that is a good idea so I don't clog up the pump... Glad this site is here. |
#4 | |
meowMEOWmeowMEOW
You can run a pre-filter but you need to check the micron size, you don't want the pump to be sucking through a big restriction.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
ahh, I forgot the vette had the return on it too.
One more question... Since I have the stock regulator on the rail; Do I still need the vette regulator? |
Has more rust than truck...
Nope, just a inline filter after the pump and a filter before the pump like 68GMCCustom if you wish. FWIW, I'm not running a pre-filter.
GM ONLY BABY!!!
I ran mine inside the frame rail. A little less visible.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
