Collector of Projects
New Style 7" LED Headlight from Truck Lite
Well I know this was covered before, but I thought I would start a new thread on a new product I found. I like the looks of this revised version of the Truck Lite LED headlight. Here is what I found...
27270C ![]() Here is thier announcement: Through continual development of improved & brighter LED forward lighting technology, Truck-Lite has developed a newly designed 7" round LED Headlamp in support of growing market interest in the product. Made in the U.S.A., Truck-Lite's 27270C LED Headlamp utilizes a completely new light delivery method, adopting parabolic reflector technology to create a smooth, even light output. The use of metalized reflector optics provides a clean and homogeneous spread of light, more uniform than other options, without any targeted or focused beams or projector-type color artifacts. Paul Sniegocki, Truck-Lite's Vice President of Research and Development stated, "We used the latest in computer-assisted optics design software to create a reflector-based system that provides an optimum lighting pattern. We essentially increased visibility to the driver, while minimizing glare to oncoming traffic, providing illumination that's safer to everyone on the road." Truck-Lite's 2007 release of the a DOT-Compliant LED Headlamp marked the first time the commercial industry was offered the benefits of LED technology for headlamp applications. The product represented a giant leap forward in creation of visibility systems, and for the first time, offered the heavy-duty industry a headlamp capable of outliving the rigors of highway driving. "We received very positive feedback on the LED headlamp's durability and increased visibility, however we understood there was a need for a more conventional and stylized design. The aesthetic appearance of the new 7" round headlamps is very sleek and modern, catering to those looking for both a rugged yet traditional appearance." reported John Howells, Truck-Lite's Vice President of Worldwide Sales. The new design, which shares features of Truck-Lite's recent 5" x 7" rectangular release, meets or exceeds FMVSS-108 and CMVSS-108 DOT requirements for both low and high beam performance. The new LED Headlamp produces light far superior to that of conventional halogen lamps, with a color temperature of 5,800˚K, closer to the color temperature of daylight. The new lamp is designed with Omni-Volt® technology to accommodate both 12 and 24 volt headlamp applications, providing crisper and whiter light output than halogen alternatives, while extending product life and adding greater dependability. The maintenance-free lamp uses a solid-state, bulb-free system that's impervious to damage caused by shock and vibration, with a military grade, die-cast aluminum housing, non-yellowing polycarbonate lens and a scratch-resistant hard coating to protect against damage from impact, roadside debris and other hazards. Truck-Lite's 7" round LED headlamp, 27270C, is a drop-in replacement for #6014, 6015, 6016, H6024 and Par 56 lamp systems, utilizing standard H4 3 blade connector. Advanced LED technology has significantly reduced LED headlamp current draw compared to halogen products, to 3.6a high beam and 1.8a low beam, allowing more power for other vehicle requirements & extending alternator life. -------------------------------------------------- Here is the older style: 27250C ![]() It seems that the Jeep JK guys are all over this new style as an upgrade. There are some pics floating around as well as some video. When I run out of necessary upgrades I will pick up a set, but right now all funds are diverted to drivetrain swap... LQ9/4L80e/NP208/D60/AAM 14bff |
![]() Join Date: Nov 2010
Re: New Style 7" LED Headlight from Truck Lite
interesting... thanks for posting that up.
a quick Google search shows quite a bit of results and some vids. Can't really tell if they are equal to or brighter than HID's, though. |
20' Daredevil (Ret)
![]() Join Date: May 2003
*Sounds* like they might be very good, effective headlamps. At $500 / pair (price I found online), they darn well better be.
Out of my price range anyway....
needs more $$$
I watched the 8 min video on them from their "lab". They look like a really good product and probably worth the $ given the technology and R&D involved...however, they are still $500 headlights. I do liked the smoked lens look though.
1970 2wd Blazer |
#5 | |
It sounds like the light dispersion is more optimized and has a cleaner cut off than HID but hard to say... |
needs more $$$
There's a good youtube vid of the lights shining on a garage door. If by light dispersion you are referring to it not shining upwards and into on coming traffic eyes, I think you are right as the lines on the garage were very defined, level and clean...just still can't get over the $500...haha...I'm such a cheap arse.
A little off topic but I feel the same about the Marquez tail lights...such an awesome product that's incredibly clean, but I just can't pay that much for tail lights.
1970 2wd Blazer |
Haha! I hear ya! That's exactly how I feel about those Marquez tails.
Almost pulled the trigger on them a couple of times but stopped myself. Had to convince myself that the price was waaay too much to spend on something that is purely aesthetic and vain. But they look so damn COOL!! |
#8 | |
needs more $$$
1970 2wd Blazer |
6>8 Plugless........
![]() Join Date: Sep 2007
I also like these LED head lights, but that price is what killed it for me. If I'm spending $500, it isn't going to be on 2 head lights.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
VA72C10
![]() Join Date: Mar 2008
Those lights do look cool! $$$ though
![]() for the guys looking at the marquez design tails...classic industry has them now...and they run 20% off sales from time to time...I almost pulled the trigger on the last sale but haven't even started on the truck I plan to put them on yet ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Well I broke down and ordered a pair for the Blazer. I figured that since I'm upgrading everything else... They should arrive next week but the truck is still in resto jail.... I'll see if I can get some updates this weekend....
We've been switching to LED lights in the Nuclear plant containment buildings where I work. Its like they put in giant skylights with the sunniest day outside. Brightest I've ever been in. Makes work a whole lot easier. Would like to see these in use at night. Might be worth it for us older drivers. Hopefully the price will come down though. That's a whole lot of beer money.
#13 |
My neighbor has a cobra kit car, and he has huge light issues, he bought some of the trucklite high and low leds. What a huge difference it made. Great product if you don't mind spending $250 each
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#14 |
If a lot of the late model Jeep JK guys are switching, they must be an improvement over the factor 2012 Jeep headlight technology... There are some good youtube videos of light comparison... I will probably put one in my Harley-Davidson too....
#15 |
I've got a set of them in my 69 camaro, they are unbelievable. This is the only pic I have that shows them.
#16 |
im ordering a set for my build for sure
#17 |
I have one of these on my Harley bagger. They are the best lighting there is.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#18 |
Cool Truck
I might just have to look into a set of these
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#19 |
I think I'll probably test one on my Street Glide and then order one more for the Blazer...
#20 |
I found them on ebay for $186. Search TRUCK-LITE 27270C Not cheap but less that $250 each.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#21 |
you will love it on the bike- I have both the gen 7 and the trucklite LED passing lamps on my glide. Cuts down the amperage on the charging system too which is nice (I run heated gear and have a "big" stereo installed on mine).
#22 |
That's a great idea. I think I'll try it on my Valkyrie then buy another and transfer to my 69 Camaro
#23 |
Snow sticks to the lens because there is very little heat output. So if you live and drive up north, wait till they come out with the heated version.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
#24 |
They are built on a huge cast aluminum heat sink.... I didn't realize how heavy they were.
#25 |
![]() Join Date: Apr 2005
Sweet lights!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
