05-22-2012, 10:00 PM | #1 |
Bed Bolt debockle
Im needing some help.... I've aquired parts and pieces to build a SWB for my 70 but i dont have any of the mounting bolts can anyone tell me what size and length i need to mount tje bed to my frame.. Any help woild be great
Posted via Mobile Device |
05-23-2012, 03:50 PM | #2 |
Restoration Virgin!
Re: Bed Bolt debockle
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-23-2012, 04:34 PM | #3 |
Might want to start with LMC to get the idea of what you want. Here is a page link, start here and page through. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=38
Also two pictures one from LMC and another from an old GSPP catalog to clarify things. I'm sure there are more suppliers. Where have you been looking?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-24-2012, 11:54 PM | #4 |
For a steel floor short fleet you need 3/8"x4" carriage bolts and you need 8 of them. Theres also some special top washers that have a offset hole.
05-25-2012, 10:38 AM | #5 |
Restoration Virgin!
Alright Gents...it's time to leave this thread alone and the bickering to stop....Cliff you are a long time member, and we expect you to set an example by being helpful....if not, please keep your comments to yourself and off these threads.....
CONDUCT GUIDELINES & ACCEPTABLE USE POLICY XIII. If you are a long time member, act like one. Lead by example and assist other newer members rather then attacking them. We look upon our veteran members to use this opportunity to teach the newer members the appropriate message board usage.
05-25-2012, 03:12 PM | #6 | |
05-25-2012, 01:01 PM | #7 |
I didn't like the look of the offset washers, so when I was putting my bed together, I just got the biggest bolt that would fit through the hole on the braces that connect to the frame and just mounted them directly to the frame without the wood being on.
The edges and the bolts in most of the metal strips hold the bed down to the cross braces. It didn't look like it hurt anything in terms of strength.
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2 |
05-25-2012, 01:30 PM | #8 |
What is the purpose of the washer with the offset hole?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-25-2012, 02:56 PM | #9 |
Steel floors have square holes punched in them that hold the carriage bolt from turning but a wood floor the square hole wouldn't be enough to hold them so the off set washer has the square hole in it and the boards are counter sunk in the bolt hole area so that with the washer off set, when you tighten them it tries to spin the washer in the counter sunk area and it can't turn.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 05-25-2012 at 03:03 PM. |
