Old 05-23-2012, 12:54 AM   #1
nlines
New engine will not start
I have a new 383 engine that will only start at 1/2 throtttle and bearly runs for a few seconds, it miss fires and sends out black smoke. It seems to be not firing on all cylinders. the timing is right and all parts are new. it has a Holley double pumper carb. any ideas?
1992 4WD Suburban 350 CI/700R Trans.
1990 2WD Suburban 6.2L diesel/700R Trans.
nlines is offline   Reply With Quote
Old 05-23-2012, 01:48 AM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: New engine will not start
You say the timing is set right, may want to turn your distributor 180 degrees and see if it still acts up
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-23-2012, 01:47 PM   #3
74 stepside
74 stepside's Avatar
Double check your ignition, vacuum, and fuel pump. Pull out #1 plug get it top dead center then pull off dist. cap and see if its pointing at cylinder #1. it sounds like your 180 off like Eyegore said.
74 stepside is offline   Reply With Quote
Old 05-23-2012, 03:21 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
I agree. Your timing is not correct.
Old 05-23-2012, 05:12 PM   #5
86dragracer
86dragracer's Avatar
Check your valve lash. If its too tight it will cause those symtoms.
2016 GMC Sierra Double Cab
1986 GMC Sierra Classic SWB
1972 Chevy Cheyenne C20 4x4 Camper Special
86dragracer is offline   Reply With Quote
Old 05-23-2012, 07:29 PM   #6
butch86
butch86's Avatar
+1 your 180 out on your timing is what is sounds like
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 05-23-2012, 10:08 PM   #7
nlines
I used a timing light when cranking the motor over and the # 1 is firing at the right time and I think if the timing is out 180 degrees it would not idle at all. I know these engines are not rocket science, I'm thinking now the valve timing or clearance is wrong. I had a machinist assemble the beast.
Old 05-24-2012, 07:08 AM   #8
1981Sturgis
1981Sturgis's Avatar
Power valve. Common on some Holley carbs. A backfire will blow them out if they don't have the kit installed.
1981Sturgis is offline   Reply With Quote
Old 05-24-2012, 08:39 AM   #9
Mikec10
Mikec10's Avatar
Bad gas?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
