Old 05-23-2012, 01:43 AM   #1
1972chevyowner
trans question
So i have a buddy that's giving his truck its a 1994 gmc with a 350 to a recycling place for scrap it has a manual trans it has a low then 1st 2nd 3rd 4th I don't know what the trans is but he said I could have any thing from the truck
I have a 1972 Chevy with a 350 and a manual trans will that work as a swap and will it benifit me??
1972chevyowner is offline   Reply With Quote
Old 05-23-2012, 05:45 AM   #2
Mrcustom
Smile Re: trans question
It should bolt right up. Just make sure you take clutch pedals and zbar
Mrcustom is offline   Reply With Quote
Old 05-23-2012, 07:18 AM   #3
hugger6933
Re: trans question
The 94 is gonna have an intragel bellhousing and hydralic clutch. There are some on here that use that trans but it is not exactly a bolt on. Also be aware the trans from the 94 has an electric speedo so you will have needs there to be addressed. Unless it is a 3/4 ton with the c6p package [8 hole wheels] Then it will have a removeable bell that may fit into your bellhousing and then you can use your clutch setup but still has the ele speedo thing
hugger6933 is offline   Reply With Quote
