Old 05-13-2003, 01:30 PM   #1
69sixpackbee
Suggestions Needed For Installing Fender Emblems
Well, once the truck is painted I will re-install the fender emblems. The problem is this, I can only access the forward-most nut on the one of the posts that hold the "Custom/20" badge on the fender. The other is back far enough to hardly even get to it because the cab frontsides cover this area. What can I do shy of loosening the fender (I do not want to do this!) at the top to gain access with my big ass hand! I thought of epoxying one in the hole and putting the nut on the other.
Thanx for the insight!
69sixpackbee is offline   Reply With Quote
Old 05-13-2003, 01:33 PM   #2
rigo
Flake Daddy
rigo's Avatar
you can put a dab of clear silicone on the emblem post.....tape the emblem on till the silicone cures......it holds the emblem tight and stops rattle.....
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 05-13-2003, 01:35 PM   #3
69sixpackbee
Thanx, Rigo!
Old 05-13-2003, 02:02 PM   #4
tom hand
CCRider
tom hand's Avatar
Thread the nut on before you start to cut threads in the post. Sears make a tappet wrench that is an open end wrench thay is 12 inches long. Tape the nut in the end of the wrench and it will start fairly easy. Tighten emblem...no problem
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-13-2003, 05:47 PM   #5
Riveted1
Tasty Cakes!
Riveted1's Avatar
Six Pack, I think there was a post not too long ago about this. Maybe try a search. I remember someone posting pics of a tool they made and some tips on getting the nuts on... Or Tom's method will work.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-13-2003, 05:48 PM   #6
69sixpackbee
Thanx!!
Old 05-13-2003, 09:22 PM   #7
Maximum Overdrive
December 21, 2012
Take your emblem to Napa and get some inserts that fit. They just slip in the holes and you are able to push your emblem on without having to put nuts on it. They make them for other types of cars it is just a matter of finding one that fits. It also lets you have the ability to take it back off easly if you want to.
Maximum Overdrive is offline   Reply With Quote
Old 05-13-2003, 10:26 PM   #8
FILICE72C10
FILICE72C10's Avatar
This is how I did it, but starting the threads would be a good start.
check this out
http://67-72chevytrucks.com/vboard/s...threadid=51434
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
FILICE72C10 is offline   Reply With Quote
Old 05-13-2003, 11:29 PM   #9
Riveted1
Tasty Cakes!
Riveted1's Avatar
Thanks Filice, that was the thread I was thinking of.....
