05-23-2012, 06:00 AM | #1 |
Disc brakes
I was wondering does anyone make a master cylinder that I can use on my 57 under the frame. I bought the whole kit from CPP and the master has a power booster and will not fit under the frame where it should. exhaust & trans are in the way. I really don't want to put it in the engine compartment so i figure I would go with a non power booster for the front discs. Thanks for any help.
05-23-2012, 09:29 AM | #2 |
Re: Disc brakes
There are guys here that mounted them farther back and made a linkage.
05-23-2012, 10:09 AM | #3 |
Re: Disc brakes
Do you know who might have done this? So I can pick his brain..
05-23-2012, 10:52 AM | #4 |
Re: Disc brakes
Another option you have is a hydroboost unit. They are much smaller then their vacuum counterparts.
05-23-2012, 12:02 PM | #5 |
Re: Disc brakes
I can't remember who's build thread it is on but there are a couple of trucks with the mastercylinder & booster mounted a ways back on the frame with long (and stout) push rods to work them.
If you are running power steering to begin with the hydro boost suggestion is a good one as they don't take up as much room and have a great feel as far as pedal. |
05-23-2012, 09:45 PM | #6 |
Re: Disc brakes
I will see if i can find the post.
05-23-2012, 09:48 PM | #7 | |
Re: Disc brakes
05-23-2012, 10:13 PM | #8 | |
Re: Disc brakes
post 200 shows the set up together. http://67-72chevytrucks.com/vboard/s...=283107&page=8 |
05-24-2012, 01:27 AM | #9 | |
Re: Disc brakes
05-24-2012, 06:35 AM | #10 |
Re: Disc brakes
How does you exhaust clear the master?
05-24-2012, 08:21 AM | #11 |
Re: Disc brakes
Looks like you have to install a trap door to access the master cylinder cover pictured above? There are late model masters which use a single point twist cover and might be fitted so they can be filled through the original access hole. 99+ S10 is one application that I can think of.
Hydroboost is ok. I've installed one in my '95 Blazer. One warning is that all hydroboost master cylinders (at least for GM) have the same size bore and it's pretty large. The pedal applies really high, but the brake effort can end up higher than expected. Last edited by 1project2many; 05-24-2012 at 08:37 AM. |
05-24-2012, 01:23 PM | #12 |
Re: Disc brakes
Hope these help... and i never have to cut a hole in the floor to add fluid..it's clears the bottom of the floor so you can put in fluid using a squeeze bottle
05-24-2012, 05:06 PM | #13 | |
Re: Disc brakes
Found this at http://www.fillingstation.com part # RR-47 |
05-24-2012, 07:18 PM | #14 | |
Re: Disc brakes
05-24-2012, 11:23 PM | #15 | |
Re: Disc brakes
i just posted this in another brake thread, look in my build thread if you need more pics.
i like the hydroboost for it's stopping power with my weak legs. if you use the mustang hydroboost you can install a remote reservoir from a nissan quest. look at orrieg's build he moved the mc back to clear other obstacles too. look at his build for more ideas. Quote:
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-25-2012, 12:11 AM | #16 |
Re: Disc brakes
I have the same kit from CPP, and don't have any issues with clearance either, so I am not sure what probs you are having, can you post some pics? I know you must use a different trans crossmember other then the stocker, and I have headmen hedders and just ran the exhaustt as shown in the previous pics.
05-25-2012, 11:14 AM | #17 |
Re: Disc brakes
the frame on a tf truck is very high above the rockers
the exhaust on these trucks hangs under the frame any brake upgrade will be in the frame lots of room under these trucks and even if you have to modify the exhaust if you can't handle an exhaust modification you probably shouldn't be working on a brake modification
05-25-2012, 11:42 AM | #18 |
Re: Disc brakes
You are a funny guy!!!!
05-25-2012, 07:11 PM | #19 | |
Re: Disc brakes
Retired and too busy to work. |
