Old 05-23-2012, 07:16 AM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Towing question - Kansas City to Dallas
Ok guys...
I have a 1972 c10 long wide.
It has a 350 bored .030 over, Trick Flow 23° aluminum heads, Comp cams extreme energy 272 cam, performer rpm intake, 750cfm carb, Doug Thorly TriY's, TH350 (built to handle the motor) with a B&M 2400 stall torque converter.
The transmission cooler is seperate from the radiator, and is in front of the radiator. No A/C in the truck, so there is no condensor.
So here's the question... how would it handle pulling a trailer from Kansas City to Dallas that when loaded weighs just under 6,000lbs?
Also, it still has the type hitch where the ball is just screwed into one of the holes in the bumper. Will that handle 6,000lbs?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 05-23-2012, 09:16 AM   #2
toddtheodd
toddtheodd's Avatar
Re: Towing question - Kansas City to Dallas
Nobody's ever pulled something heavy with a hopped up motor and a 2400 stall???
IIOY???
Old 05-23-2012, 09:25 AM   #3
haysonj
haysonj's Avatar
Don't know what gears you have but if you have 4:10 or lower you will be cruising at 3000 or more and that is not good. I also would not tow 6000 lbs on a bumper hitch. It can be done if the trailer is loaded right but still not a good idea.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-23-2012, 09:32 AM   #4
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
I wouldn't tow that much weight on a bumper hitch.
And the higher stall torque converter may slip while towing
and cause your trans to overheat.
my .02
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 05-23-2012, 09:54 AM   #5
MrSchaeferPants
MrSchaeferPants's Avatar
Nope, and I haul quite often with a 1/2 ton wee 6, with loads that heavy. But it's a newer truck, that handles better, and better braking, and weighs more. You NEED a nice heavy duty hitch at least, and with 6klbs, preferably a brake controller, and trailer brakes.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 05-23-2012, 10:20 AM   #6
toddtheodd
toddtheodd's Avatar
Oh yeah... 3.08 gears.
The trailer would have a surge brake on it. One of the flat car haulers from U-Haul, with a 1995 Oldsmobile Delta 88 on it.
I was thinking of loading it so that the weight wasn't all on the tongue of the trailer... basically back the car on it.
I know the car is 3500lbs, and those trailers are like 2000lbs... that's why I said 6000lbs, so that I would have a margin of error.
IIOY???
Old 05-23-2012, 10:30 AM   #7
MrSchaeferPants
It might be 2k for the trailer, paperwork might say? Our 21ft dove tail hauler is about 2k. I'm suprised, I don't think the U-hauls here would rent that to me if I said what I was towing, with that sized vehicle.
Well, if you already have it, load it, see what happens, look at how the truck squats, keep in mind if it brings your rear end down quite a bit, your front will raise, you may notice a difference in steering, and breaking. Like I said, I haul a bit more than that with a 1/2 ton, but it's never very far. Stay in the slow lane, should be a pretty flat drive which is good. Brake early, and don't ride anyone's ass.
Oh but DO get a class 3 hitch. The balls on the bumper are for pulling little fishing boats and landscaping trailers, that's it.
And keep in mind, that trailer will be pushing you. They call them BUMPer pull trailers for a reason. Towing's not just about engine size and transmission, there's a difference between pulling, and towing.
Stay Safe
Old 05-23-2012, 11:16 AM   #8
LEEVON
Moderator
LEEVON's Avatar
I say sell the Olds and get another one in TX so you don't have to mess with it!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-23-2012, 11:23 AM   #9
MrSchaeferPants
I'm partial to Olds, but not a 87+. Unless it was an Aurora. Sell it and get a 3/4-1ton for future use
Old 05-23-2012, 11:37 AM   #10
haysonj
haysonj's Avatar
Be very careful about backing it on the trailer(not enough tongue weight) I brought my 4x4 from AZ to Calif on that same Uhaul trailer. Had to back it on because the 4x4 is wider in the front. I could not go over 45 without it starting to fishtail. If I had to do it again I would have bought some bags of sand and thrown in the pickup bed.
Old 05-23-2012, 12:25 PM   #11
Ackattack
Ackattack's Avatar
I would make sure I have a trans temp guage and a frame mounted hitch.
I would also contact U-hual to make sure they'll rent you that trailer for that car in your truck. I've used a few of those trailers and they seem to be really tongue heavy, and don't allow you to move the car back to adjust the tongue load.
Ackattack is offline   Reply With Quote
Old 05-23-2012, 05:16 PM   #12
blackdawn
my 2 cents, first i dont think a bumper will handle that kind of weight pushing and pulling on it, it may get you there but be incredibly tweaked, id say get a true hitch setup. second after renting many u-haul trailers i have found that their surge breaks are next to useless. they never service the trailers, so i have had nothing but bad experiences with them. I ended up roasting the brakes on my 3/4 ton pulling one of those with a 4k vehicle on it.
1969 c-10 short bed stepside - work in progress
blackdawn is offline   Reply With Quote
Old 05-23-2012, 08:32 PM   #13
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I agree on all this..I wouldnt even think of towing that kind of weight with a bumper hitch...and as far as a U-Haul trailer I may trust one to go across town but no farther! they are notourius for blown tires, smoked wheel bearings and bad lights. They get turned in from who knows how far of a trip and its right back out again.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-23-2012, 09:34 PM   #14
SS Tim
SS Tim's Avatar
I cannot agree more with the advice given. It is too much for you hitch and really your truck as equipped. The engine mods seem more top end oriented and I'm suprised that you are running 3.07 gears with it (short tires???).
But for the sake of accuracy, here is the offical Chevrolet "REQUIRED EQUIPMENT ON PICKUPS & SUBURBANS FOR TRAILER TOWING" chart form the 1972 Silver Book.
SS Tim is offline   Reply With Quote
Old 05-23-2012, 09:46 PM   #15
old Chevy guy
old Chevy guy's Avatar
DON'T put the car on backwards! trailers loaded heavier in the rear do some crazy stuff. I had to load a car backwards on my trailer once (long story). I was towing it with my 67 3/4 ton GMC camper cruiser with a V6. I was almost back to my house when I got going a little to fast and when the trailer started to fishtail ,as they will loaded that way, it almost flipped the truck. Very scary,lessen learned!
old Chevy guy is offline   Reply With Quote
Old 05-23-2012, 10:38 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
X2 i will never tow one backwards again if i can help it bad experiences
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-23-2012, 10:48 PM   #17
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Backwards on the trailer is a recipe for disaster
powerdriver 1958 is offline   Reply With Quote
Old 05-23-2012, 11:39 PM   #18
ls1nova71
ls1nova71's Avatar
What's the story on the Olds? With the engine/trans in your truck, and pulling a trailer you're going to be getting some awful gas mileage. Factor in getting a better hitch, because there is no way you could safely tow that much weight for that distance with a bumper hitch, then it would seem to me it would be cheaper to get a plane ticket and fly in and drive it home. You'd save one night hotel money too, unless you were going to bonzai it up and back.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
