Old 05-23-2012, 11:46 AM   #1
66 Burban
66 Burban's Avatar
62 Chev Short Fleet on 65 Chev Short Fleet Chassis?
Will a 65 Short Fleet chassis work under a 62 Short Fleet? If so, what mods are required?
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 05-23-2012, 01:37 PM   #2
62 short step
62 short step's Avatar
Re: 62 Chev Short Fleet on 65 Chev Short Fleet Chassis?
You will have to get the front cab mounts off the 62 frame and put on the 65 frame.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 05-23-2012, 01:57 PM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
So....Im assuming the same hold true for a '62 burban ?
(beside wheelbase and rear frame/bumper ?)
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-23-2012, 04:57 PM   #4
62 short step
I would imagine so.
1965 c-10
86 chevy c/k 20
Old 05-23-2012, 05:08 PM   #5
slepysal
slepysal's Avatar
John when you picking up your Burb ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-23-2012, 11:45 PM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Later part of July ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-24-2012, 12:21 AM   #7
Captainfab
60-66 Nut
When I replied to your PM about this, I somehow read a Suburban into this....sorry about that. I guess it was your user name......
If it is a '62 truck body onto a '65 truck frame, you can just drill new holes for the front cab mount bolts. The '62 cab mounts will sit on the frame brackets just fine, just need to drill new holes. Next the bed cross sills will need either a piece added to them to sit on the '65 frame bed mounts, or extend the frame brackets to accomodate the '62 cross sills. The other issue is the rear bed sill. It has brackets that are spot welded ont it that sit on top of the frame. The '60-'62 frames are wider in the rear than the '63-'72 frames. So the '62 rear cross sills won't sit on top of the '65 frame, they will be on the outside.
Old 05-24-2012, 11:14 AM   #8
66 Burban
66 Burban's Avatar
Thanks, Captain Fab!!!
I assumed that was what happened with the PM!
Thx,
Billy B.
