Is this rearview mirror correct ?
Hey guys, This mirror was in my truck when i got it. ( not installed, on the floor ) and wanted to know if this is a correct , genuine GM part for my 68 SWB Chevy and not an autozone , pepboys rear view mirror. Also does this goes screwed onto the the top of the cabin or glued to the windshield ?
![]() By frijolito1988 at 2012-05-23 ![]() By frijolito1988 at 2012-05-23 ![]() By frijolito1988 at 2012-05-23 |
Re: Is this rearview mirror correct ?
That mirror's swivel arm and the boot that covers where it attaches to the inside roof of the cab look exactly like the rear view mirror in my 67 cab and all the roof mount ones I've seen in junkyards.
I'm sure someone will chime in with the exact years that had roof mounted and windshield mounted rear view mirrors but I do know that the cab roof mounted were the earlier style (67-?) and stuck to the windshield was the later style (?-72)so for your 68 it s probably correct. |
As far as I know '67-'71 rear view mirrors were mounted to the roof of the cab with that bracket you have, and '72 they were mounted directly to the windshield.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
I can't vouch for authenticity, but this is mine and where it mounts (I assume with all the "patina", that it's original):
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Thank you for the replies.
It appears the 67-71 had 2 kind of brackets http://www.classicindustries.com/tru...ts/cx1056.html ( rubber ) http://www.classicindustries.com/tru...ts/cx1055.html ( Chrome Metal ) and the 72 was glued to the window. Thanks guys! |
Active Member
![]() Join Date: Oct 2002
That is the 1969 - 71 style mirror
![]() Join Date: Feb 2011
This is the one in my 67.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
Thanks! That is the kind im going to order I like that one the best.
Old member
I'm not sure of all the years but I do know that is a stock mount and mirror for a 71 Custom Deluxe Chevy truck. That is the exact mirror and mount I had in mine until I swapped it for the late model temperature one.
![]() ![]() I used the cover to hide the holes after installing the late model mirror.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
