05-23-2012, 03:53 PM | #1 |
now i have a dana 60 question
ok soi wanna straight axle my dually which is a 75 and i found a ford and a dodge dana 60 with 4:10 gears which is what i need but both have differantials on driver side. is there anyway i can make a newer transfer case work or? i heard you csn flip a np205 and make it work for driver side is that true?
05-23-2012, 04:06 PM | #2 |
Re: now i have a dana 60 question
ops i meant to put this in the 4x4 section. is there a way i can move it over there or can addmin?
05-24-2012, 10:13 PM | #3 |
Currently Blazerless
I'm dont know about flipping a case...I'm sure if it can be done it would be a lot of work...you may be able to use some type of Ford transfer case..what are you going to be using for a trans? I would stay away from that Dodge Dana 60, if its a drivers side drop it must be a 94 or newer..they have unit bearings and are coil sprung. Unless your getting a real good deal on that Ford 60 I would keep looking for a GM version...it would save you a lot of work!
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
05-25-2012, 06:51 AM | #4 |
There is also some differences between the GM D60 and the Dodge D60. Like already stated it must be a newer one if its driver drop. I think it would be more work than what its worth, i would try and find a GM dana 60 and then have much less work ahead of you even if you have to spend a little more to get a GM axle.
05-26-2012, 01:33 AM | #5 |
the ford 60s $500 and all the chevy d60s for a dually are $800 plus without springs
06-03-2012, 12:55 PM | #6 |
But the transfer case/transmission adapter is going to cost way more than that $300. Buy the GM D60 and don't try to reinvent the wheel. Oh, and $800 for a GM 60 is a pretty good price.
06-03-2012, 04:35 PM | #7 |
800$ is a good price for a gm d60 if its got everything
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
06-04-2012, 05:16 AM | #8 |
i was supposed to get one with matching gears(4.10s) amd springs steering steering box everything and he sold it even tho he was supposed to hold it for me
06-09-2012, 05:02 PM | #9 |
I only hold parts for people who put up a non-refundable deposit myself, too many people never return. Conversely, giving my word is worth more than money, so I ask for a specific time frame
