Old 05-23-2012, 04:18 PM   #1
Mike Honcho
Mike Honcho's Avatar
2000 rust problems?
Anyone else had problems with rocker panels and cab corners on 2000 model Silverado? Mine started bubbling the paint when it was around 6 years old and just got worse from there. I was just wondering if this was a common problem or if it was just mine.
1972 GMC long bed
1967 GMC long bed
1970 Chevrolet CST shortbed
1967 Chevrolet K20 suburban
1957 Chevy 4x4 1/2 ton
Mike Honcho is offline   Reply With Quote
Old 05-23-2012, 04:39 PM   #2
truckdude239
truckdude239's Avatar
Re: 2000 rust problems?
pretty common
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-23-2012, 10:03 PM   #3
bighaas79
around here it's harder to find one that doesn't look like that.
bighaas79 is offline   Reply With Quote
Old 05-23-2012, 11:00 PM   #4
crazy longhorn
Fabricate till you "puke"
Yup, I have to fire the welder on my 02....she was an Alabama truck, that made her way to Illinois. It will be rockers/cab corners, & wheel house outers, over the box. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-23-2012, 11:19 PM   #5
Justin87
Justin87's Avatar
The cab corners on my 2000 Sierra are starting to rust.
2006 Silverado 2500 HD
Justin87 is offline   Reply With Quote
Old 05-24-2012, 04:21 PM   #6
dyrt
circa 2000 must have been a bad time for steel or something. My mom's 2000 suburban has some of the worse bubbling and rust on the bottom side that i have seen on a vehicle with that few miles. I admit there is some salt on the roads here during winter but the chassis paint looks like the metal was rotting from the inside out, like it was scaling and blistering.
On a side note, if you are having problems with your sheet metal, take a good look at your brake lines also. One of hers blew and it was a bear to replace. the lines looked like they were from the titanic in spots yet perfectly ok in others.
dyrt is offline   Reply With Quote
Old 06-27-2012, 01:42 PM   #7
Slammed67
Progress = 0%
Slammed67's Avatar
Having the same issues with my 2000 GMC. Driver side rocker is 75% rust, rear wheel arches on both sides are are quickly rusting away. Cab corners show no signs of rust (yet).
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
