05-23-2012, 04:27 PM | #1 |
BIG CHEVY 3600 LONGBOX
Break petal too high
My petal is about 4/6" too high. I have a 51 3600 with V8 and 700R4 tranny and disc brakes all around. The only solution I can think of is cutting a few inches out of the rod. Would there be a better solution?
http://s729.photobucket.com/albums/w...=Interior1.jpg
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
05-23-2012, 06:29 PM | #2 |
Re: Break petal too high
I take the pedal shaft off & cut it right underneath the pedal. Cut off the amount you want & weld it back on.
05-23-2012, 06:33 PM | #3 |
thats what I did on dads truck also
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
05-23-2012, 06:38 PM | #4 |
That's what I suspected I would have to do. I just thought someone had a better way. I hadn't thought about cutting at the back of the petal. That would make my weld less visible. Thanks guys.
05-24-2012, 11:38 PM | #5 | |
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-25-2012, 08:58 AM | #6 |
before you cut anything....
did you install the rubber bumper/pedal stop? justplainray |
05-25-2012, 09:06 AM | #7 |
Yes I put the bumper on.
05-25-2012, 08:51 PM | #8 |
A320 Pilot/USAF Retired
Before you cut it, make sure you check that you have full travel with the engine running if you have power brakes. Ask me why I say this? Well I cut one to short because I measured what I wanted to remove without vacumn and it ended up being too short!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
05-25-2012, 10:58 PM | #9 |
Thanks Chuck, and excellent point I had not considered.
