Old 05-23-2012, 09:42 PM   #1
seafoam68
seafoam68's Avatar
CPP rear sway bar
Hey guys, has anyone used the CPP rear sway bar? I picked up a brand new front and rear for a great price. One problem so far is the trailing arm brackets don't line up right. The hole on one side of bracket will go into trailing arm, but the other hole hits right in the center of where the two halves of arm meet. Also, I have heard some say don't use a rear arm on lowered trucks. Mine is lowered with CPP 5 inch springs and delux trac bar. Thanks...
seafoam68 is offline   Reply With Quote
Old 05-23-2012, 10:00 PM   #2
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: CPP rear sway bar
I have those same swaybars. The front is installed, but not the rear yet.
I take it yours did not come with instructions. You have to drill some holes
to install the bar. Go to the CPP website and look up the directions for the swaybar.
VDOG is offline   Reply With Quote
Old 05-23-2012, 10:05 PM   #3
Tmwoodall
I would be curious to see how people feel about them in general. I ordered a set, was backordered. I called ECE in the meantime they suggested only running a front, so I bought theirs instead.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 05-24-2012, 05:46 PM   #4
seafoam68
seafoam68's Avatar
Anybody else?
Old 05-24-2012, 05:51 PM   #5
Smoothride
I would like to know before I order a back sway bar for the back also
Smoothride is offline   Reply With Quote
Old 05-24-2012, 06:00 PM   #6
big_al_71
big_al_71's Avatar
I had both front and rear in my truck for a few years. They worked perfectly, when I replaced my rear trailing arms with the square tubing from ECE I did not re install the rear sway bar as it would not fit and when I installed the air ride I replaced the front sway bar with the muscle bar from Ride tech.
If you are running the stock rear trailing arms and just have a static drop or stock height I would highly reccomend them..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
