Old 05-23-2012, 11:03 PM   #1
Mike Honcho
Mike Honcho's Avatar
Re-drilling rotors
Has anyone ever tried to re-drill 5-lug disk rotors for 6-lug? I want to convert to disks on my 66 but i would like to keep my 6-lug rally wheels, plus i don't really want to change the rear. I have a complete front and rear from a 72 to do a swap with. I tried one of the rotors with the wheel studs removed up to a 6-lug wheel and it looks like if the holes were welded and re-drilled it would work. Just wondering if anyone else has tried this and if so did it work out for you?
1972 GMC long bed
1967 GMC long bed
1970 Chevrolet CST shortbed
1967 Chevrolet K20 suburban
1957 Chevy 4x4 1/2 ton
Mike Honcho is offline   Reply With Quote
Old 05-23-2012, 11:39 PM   #2
lil hoodlum
lil hoodlum's Avatar
Re: Re-drilling rotors
If it were me, I would just buy some six lug rotors.
I put disc brakes on my 68 and kept it six lug.
Good luck!
Keith
lil hoodlum is online now   Reply With Quote
Old 05-24-2012, 02:48 AM   #3
hotrod100
hotrod100's Avatar
You can buy the conversion rotors from the truck and car shop. That will let you keep them 6 lug. I did the same thing when I put an '83 subframe in my brothers '62. They're part #60-152011 and they run $75.00 each.
My build thread.
hotrod100 is offline   Reply With Quote
Old 05-24-2012, 07:30 AM   #4
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
FYI - I tried laying these two patterns out in AutoCAD some years ago. Regardless of position, one of the (6) holes will partially overlap (breakout) in one of the (5) holes. I suppose it could be welded up and re-drilled, but I'm with the guys above. Unless you are a "full-on" welder and machinist, I'll bet you can buy the new rotors for less $$$.
TobyArnot is offline   Reply With Quote
Old 05-24-2012, 11:06 AM   #5
Mike Honcho
Thanks for the replies. I didn't realize new ones could be bought for $75 each. That's probably what i'm going to do as i already have everything else to do the brake swap. I like keeping the cost down on this stuff but if $150 will make life easier i'm all for it.
1972 GMC long bed
1967 GMC long bed
Old 05-26-2012, 07:04 AM   #6
mbgmike
Just for info we redrill and plug all axles-shorten rear ends-axles- all makes
95.00 to plug and redrill a pair
mbgmike is offline   Reply With Quote
