Comp Cam Vs Scorpion
Just wanted to see if anybody had any input on rockers.
Its a 540 bbc Looking at scropion part #1014 vs Comp Cam part # 19021-16 Thanks
My 1970 C10 Build "Project Teacher" Last edited by garykirby25; 05-24-2012 at 11:47 AM. |
Re: Comp Cam Vs Scorpion
I have the 1014 Scorpions on my truck. 990 heads, .703" lift Herbert cam and good pushrods/guide plates. No complaints after 3 seasons of 7000 rpm shifts. They replaced a set of unknown brand rockers that were wore smooth out. You must check the rocker to valve spring clearance and verify the wear pattern on the valve stem.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
I was facing the same decision a few months ago. Ended up going with Crower Endure series.
Thanks for the info, the race shop that built my engine told me they havent had any problems with scorpion so thats what i went with. I know there not the only one, but made in the USA still means something to me.
My 1970 C10 Build "Project Teacher" |
That's one of the reasons I used them, also. Good luck.
Had a set of scorpions on my SBC, they were bulky and hit my valve covers. They were also noisy. Switched them out for a set of Harland Sharps.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
We ran these on the modifieds for 11-12 years. Zero issues. I have a set in my truck now. I couldn't, tell you if their loud. Between the should roller cam and flowmaster hush powers with no insulation on the floor . Can't tell what's making noise,everything is loud.
#8 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Are you talking about the Scorpions or the Comp Cams roller rockers?
Sorry, Scorpions.
