quick ??? on gas tank?
My gas tank stops at 10 gallons always
idk why? its a 74 chevy custom deluxe short bed so it suppose to have 16 gallon tanks right? Ive been looking online and cant find anything went to gm-heritage website and it said there suppouse to be 16 gallon tanks it has 2 tanks but I only use the one on the driver side could it be something to do with the sender or float any input would be greatly appreciated ![]() |
Re: quick ??? on gas tank?
Sounds like the float is out of adjustment. As to only being able to use one tank, that sounds like a wiring or switching valve problem. Could also be the switch in the dash, but my guess is the valve under the truck. Have a friend sit in the truck and flip the switch while you listen to the valve under the truck. If you can't hear anything, replace it. I got mine at NAPA, granted our valves are a little different since mine is a 1989 R3500. Same principle though. Good luck with it.
Is it easy to adjust the float?
am i gonna have to take my bed off to get to my tanks im only using the drivers side, because when i got the truck the po said he had only been fueling up the drivers side so im saving up money to buy or clean the passenger fuel tank and get the valve and hoses that not gonna be until next month tho How do i adjust it |
Yes - it's a 16 gallon tank, but keep in mind not all of that is "usable".
So, depending on how much is laying in the bottom, and how low you run it down 10 to 12 gallons on a "fill up" could be reasonable. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
