Old 05-24-2012, 02:06 PM   #1
doublearrow
engine temp
I posted this in another section, I think this is the more appropriate spot so I am deleting the other thread.
i had a weird occurence with my truck this morning. 1987 4x4 silverado 350 tbi. I do not know at what temps the actual guage runs at. It has 4 tick marks. It will rise slightly past the first tick mark until the thermostat opens then drops below the first tick mark. This is the way it has always run. This morning when I hit 70 nph it bounced quickly up and down to the second tick mark. I slowed down and it went to normal. I sped up again and it bounced directly way past the "HOT" it went as far as it could go. It stayed there for roughly 5 to 10 seconds then back to normal. It did this a couple of times. My question is did mmy engine overheat? It was not a gradual bounce it was a very quick eratic almost bounce. Do I have more of an electrical problem? This forum has been very helpfull and I appreciate all of the help
doublearrow is offline   Reply With Quote
Old 05-24-2012, 02:23 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: engine temp
I would doubt that your motor overheated. I would make sure the connections are clean on your temp sender and if that works out I would either temporarially put a mechanical guage under the hood to prove your truck is running at normal temp or swap out the sender unit.. In all likelyhood its just the sender or its connection
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-24-2012, 03:32 PM   #3
rfmaster
rfmaster's Avatar
Re: engine temp
Gauge going all the way past right most tick mark (270F) is a result of a dead short of the sensor wire to chassis ground..
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
