05-24-2012, 11:07 PM | #1 |
tire advice?
im looking for a new set of rubber for my 72 1/2 ton chevy, with all the posts that are on tire websites i dont seem to get a recomendation i could use. I keep getting "they look cool". thats a small part of it though.what im looking for is a 33 or 35x12.5x15,im not rich, dont want to have to turn up the radio to try to kill road noise(not that i couldnt),a decent tire should run around $200. ea? and maybe a mildly agressive tread. Any info you could share would be helpful....thank you
05-24-2012, 11:12 PM | #2 |
Currently Blazerless
Re: tire advice?
I've always had good luck with BFG ATs, I'm running their 35" MTs on my truck right now and there quite and ride nice.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
05-24-2012, 11:15 PM | #3 |
20' Daredevil (Ret)
Re: tire advice?
First let me ask if your truck is lifted. You could probably get by with no lift (or a 2.5" lift) with 33" tires, but going to 35s will require a 4" lift.
Also, what type of use do you expect they'll get?
05-24-2012, 11:37 PM | #4 |
Re: tire advice?
I would take a serious look at Hercules trail digger, very good tires.
1978 GMC K25 2002 Dodge Dakota R/T rc swb In need of some more goodies. |
05-25-2012, 07:41 AM | #5 |
Re: tire advice?
My brother has had bfg at on his f150 for 5 years and loves them,They are kinda quiet for a truck tire and do good all around from snow to light off roading.
05-25-2012, 09:52 AM | #6 |
Re: tire advice?
If your truck is close to my 76, it will not require a lift to run 35s. The only thing is the front of the fenders will require a little trimming, but if yours are like mine and all body filler, they trim themselves.
I am never putting a lift on my truck. Last edited by 76k10; 05-25-2012 at 10:01 AM. |
05-25-2012, 11:30 AM | #7 |
Re: tire advice?
it does have a 6" lift on it, fitting isnt a problem. my only issue with running anything bigger than a 33 is that a few years ago,the three studs that hold the pitman arm to the steering knuckle sheered off at the knuckle.1 was broken for a long time and another was half broke for probably the same amt. of time. when tyhe last one completlely broke that was a scary moment. I was doing 50 mph!...had the knucke machined and bought new studs, but its always in the back of my mind.
05-25-2012, 11:32 AM | #8 |
Re: tire advice?
ive got a 72 with a 6" lift, they'll fit..its the extra stress on the steering componets that iam concerned about.
05-25-2012, 11:33 AM | #9 |
Re: tire advice?
05-25-2012, 11:35 AM | #10 |
Re: tire advice?
05-25-2012, 11:36 AM | #11 |
Re: tire advice?
ive got a 72 with a 6" lift....a 35 will fit easily its the extra stress on the steering that i worry about
05-25-2012, 11:37 AM | #12 |
Re: tire advice?
05-25-2012, 12:15 PM | #13 |
Re: tire advice?
I just bought Goodyear Duratracs for my suburban with a 6" lift. The tires are 33x12.5x15 and they were $196 thru Americas Tires. Awesome tires! They're a severe weather tire. Great in snow and on ice. I'll post up a picture soon.
05-25-2012, 07:19 PM | #14 |
20' Daredevil (Ret)
Re: tire advice?
IMO, a 33" tire will look too small with a 6" lift, so between your two sizes, I'd go with 35s.
Take a look at General Grabber AT2. Nearly everything I have read about them is good, and they are less expensive than BFG ATs. They are slightly less aggressive but get good reviews.
05-25-2012, 08:00 PM | #15 |
Re: tire advice?
Here's my pictures.
[IMG][/IMG] [IMG][/IMG] |
05-25-2012, 08:25 PM | #16 |
Re: tire advice?
I have Wrangler Duratracs too. AWESOME Tire!
