Old 05-25-2012, 01:02 PM   #1
J Lee
J Lee's Avatar
coys wheels with hd brakes
I have the HD brakes 1 1/4" rotors on my '79 and would like to run coys wheels but I know some wheels (maybe most) dont fit correctly over the rotors center hub. anyone know for sure if they'll work?
Jeff
J Lee is offline   Reply With Quote
Old 05-25-2012, 01:08 PM   #2
SCOTI
SCOTI's Avatar
Re: coys wheels with hd brakes
Jeff
They fit. The center cap needs to be spaced out slightly or it will contact the wheel bearing cover. Some guys put a spacer behind the wheel while others opt to make a spacer just for the center cap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-25-2012, 01:15 PM   #3
J Lee
J Lee's Avatar
OK thanks SCOTI, dont happen to know how thick a spacer it takes do you?
Old 05-25-2012, 01:29 PM   #4
cochino12
It followed me home?
cochino12's Avatar
My '84 has hd rotors and coy's with no spacers or issues.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-25-2012, 02:53 PM   #5
SCOTI
SCOTI's Avatar
The ones I had were about .125". Perhaps Coy's corrected the cap depth issue since it sounds like Cochino didn't have issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2012, 04:59 PM   #6
J Lee
J Lee's Avatar
OK thanks for the help guys, this has been a big worry of mine. I thought about changing over to the 1" rotors setup but really prefer to stay with the heavier brakes.
Jeff
