what rear end gear in 1977 c10
I have a 12 bolt rear 6 cylinder 250 trying to calculate speedometer swap I put in a t5 5 speed and have 20s but dont know what rear end setup I have does anyone know Thanks
Re: what rear end gear in 1977 c10
Nope. Nobody knows. And nobody is gonna know until you pull the cover and count teeth - or roll the tires and count driveshaft revs.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Now - if you are asking what was available, well - that is known.
RPO HE4 3.40 was standard, and GT4 3.73 was optional, so you'd have to find your SPID label and see if either of those are noted. Regardless, that would assume that no one has changed it in the interim, so really the only way to know is check the parts as mentioned above. K
#4 | |
My 1977 1/2 ton strippo 250/3spd has a 12 bolt with 2.73's. Appears to be stock. My 1982, 84, and 87's all have 3.08's 10 bolts.
Buy a cover gasket and 2 qts lube, pull the cover, and count. It probably could use clean fluid anyway.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Moderator
![]() Join Date: Oct 2008
If you're lucky you'll find a part number or tooth count stamped on the ring gear as you spin it.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I pulled cover and counted 34 ring gear 10 pinion gear so I guess its a 3.40
I think id like that 3.73 more low end. What are you guys running I have 5 speed and inline six once the motor is done up I may like the 3.40. |
with the 5 speed i think 3.73 would be pretty good. its a commen gears to pair up with the 700r4 and they have about the ame final gear right?
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
