Old 05-25-2012, 03:59 PM   #1
jsdoyle
jsdoyle's Avatar
Having to stand on them
My new truck has a brake booster, disc up front and drum rears. I've not pulled the tires yet to inspect the brakes but I really have to puts some effort in pressing that brake pedal.
Before I get started do you guys have any suggestions or ideas on what to look for? I know I'll have to pull the tires but are there any adjustments otherwise to try?
Thanks!
jsdoyle is offline   Reply With Quote
Old 05-25-2012, 04:16 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Having to stand on them
Vacuum leak to the booster would be the 1st thing I'd check.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-26-2012, 08:34 AM   #3
jsdoyle
jsdoyle's Avatar
Thanks, I did check that and to my surprise the hose end that fits in the valve cover gasket was pulled out. Thinking "shazam!" I put it back in and away I went.
No luck... So much for that! I'll still check to make sure I'm getting vacuum at the boost end.
Thanks!
Old 05-26-2012, 09:57 AM   #4
Hotrob72
Hotrob72's Avatar
The hose from the boster does not go to the valve cover, go's to manifold to gain vacumn
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline   Reply With Quote
Old 05-26-2012, 11:51 AM   #5
jsdoyle
jsdoyle's Avatar
Yeah. That's right. I had to take the air filter off to find it.
Popped the fluid resevouir lid off and found out it was low on fluid. Should have started there. New fluid makes a hell of a lot of difference!! Now keeping my fingers.crossed theres no leak somewhere.
Old 05-29-2012, 11:41 AM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Fluid doesn't typically evaporate from the reservior...I'd go through your lines to see where the leak is.
1970 2wd Blazer
Old 05-29-2012, 11:48 AM   #7
jsdoyle
jsdoyle's Avatar
You are right. It's empty again. So, looks like I've got a leak.
Old 05-29-2012, 12:48 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
With it emptying that fast, hopefully it's easy to find at least!
1970 2wd Blazer
Old 05-29-2012, 08:52 PM   #9
Scottshotrods
Do you happen to know what the bore size is in your master ?
Justin
Scottshotrods is offline   Reply With Quote
Old 05-30-2012, 12:13 AM   #10
jsdoyle
jsdoyle's Avatar
Justin
Dont know off the top of my head. How would I measure that?
I checked for leaks tonight and haven't found one. Yet.
So the master cylinder has two chambers. The one toward the booster keeps emptying. There is brake fluid in the engine compartment under the master cylinder.
So is there an issue with the master cylinder and it loosing the fluid due to too much pressure? Brake lines not blead properly?
Scott
Old 05-30-2012, 10:19 AM   #11
Scottshotrods
Scott
Measure the opening of your two different ports on your master
Justin
Old 05-31-2012, 12:51 AM   #12
jsdoyle
jsdoyle's Avatar
Justin
Well they measure right at 2 inches wide at the top. I'll post a picture in the morning of the master cylinder setup. Thanks!
Old 05-31-2012, 08:20 AM   #13
jsdoyle
jsdoyle's Avatar
Here are a couple pictures of the booster/MC. You can see how some of the brake fluid is on the MC. When I first opened the MC the reservoir closest to the booster was empty. I added brake fluid and after 2 days of driving it was empty again and the MC had brake fluid on it and some was on the wheel well below the MC.
I refilled the MC Monday and after driving last night I see no loss of fluid.
I've not found any leaks other wise but I've not pulled the wheels. I have looked across at each wheel from under the truck and I don't see any signs of a leak. Not that doing that will tell me much.
The truck has disc front and drum rear.
Old 05-31-2012, 11:57 AM   #14
Scottshotrods
I would change out the master you have on your truck to a new one
Justin
Old 05-31-2012, 12:08 PM   #15
jsdoyle
jsdoyle's Avatar
Justin
Any recommendations?
Old 05-31-2012, 12:13 PM   #16
Scottshotrods
Call us at the shop and we can help you out for sure.You can reach us at (805)485-0382
Justin
Old 06-07-2012, 07:35 PM   #17
starvinartis
MC may be leaking into the booster? Also that looks like a drum brake MC, disc/drum should be bigger, at least on one side if not both. I agree with Justin, change out the MC
starvinartis is offline   Reply With Quote
Old 06-21-2012, 12:32 AM   #18
Lugnutt
Lugnutt's Avatar
I may be a little late on this but I've had the same problem before. It turned out to be a hole in the back of my vacuum reservoir. Turns out that it was rubbing against something (can't remember what) and wore a hole right through it back where you couldn't see it; everything was factory stock too. I changed mine out and problem solved.
Lugnutt is offline   Reply With Quote
Old 06-21-2012, 08:23 AM   #19
jsdoyle
jsdoyle's Avatar
Thanks Lugnutt! I ended up fixing them last Saturday. I bought a new master cylinder and brake booster from Autozone for 105 bucks and put those in the truck. I'd never installed those and it's been a while since I had a car/truck I could work on but I got the job done and now my brakes are excellent! I barely have to tap the pedal now. What a difference it made!
I put in a booster and master cylinder for a 74 C10. The only hitch I had was the booster rod to the brake pedal wasn't long enough. I had to make an extension about 2 inches long and that was it!
Lovin' the new brakes!!
