Old 05-25-2012, 04:29 PM   #1
Mack B
Mack B's Avatar
Truck unlevel after lowering
I actually did this months ago, but just recently decided to investigate, I installed a 3/5 cpp spring kit on my 63 lwb pickup and the passenger front is about an inch higher than the driverside, I confirmed the springs are seated right, and hoped they would settle. I later noticed this situation goes away when I put the rear of the frame on jack stands....thoughts? Could a binding issue in the rear cause this? Like a shock bottomed out or something? I can't visually see anything wrong, just looking for ideas, thanks. oh and it's very possible this existed before the lowering, but I didn't notice it. Thanks for any help!
Mack B is offline   Reply With Quote
Old 05-25-2012, 05:16 PM   #2
CdM
CdM's Avatar
Re: Truck unlevel after lowering
is the trac bar in the rear stock? if so is the side where it mounts to the frame that is lifted? I think with a 5 inch u need a adjustable trac bar/pan head whatever its called lol
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 05-25-2012, 05:23 PM   #3
Mack B
Mack B's Avatar
It's the opposite side, I did have to get an adjustable trac bar, it almost pushed the passenger tire out the fender opening lol. Thanks for the fast reply
Old 05-27-2012, 12:33 AM   #4
Mack B
Mack B's Avatar
Juuust incase someone who may know the answer, might have missed this
Old 05-27-2012, 10:04 AM   #5
txinliner
txinliner's Avatar
i bought the same kit and have the same problem mine is higher buy a half inch on p.s. ive checked springs , cab mounts etc.
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 05-27-2012, 02:11 PM   #6
Mack B
Mack B's Avatar
That's interesting, in the near future I'm gonna add dropped spindles to the front and blocks to the rear, I think at that time I will swap coils side to side and see what happens. Anyone know of any drawbacks to trimming just one coil if need be? Yea that sounded like a horrible idea just typing it lol.
