Old 05-25-2012, 05:50 PM   #1
Raked 64
Raked 64's Avatar
Help me with wheels!
I am finishing up my 64 C-10 and I am stuck on a wheel decision.
I have a 2.5" drop spindle kit/disc brake with lowered springs in the front
and a 3" drop spring in the rear. ( I may add a 1" lowering block)
The wheels I want are the Boss 338 or something similar. The plan was to go 20" all the way around. I am not sure I want to swap to 5 lug. Do you know where I can get the wheels I am looking for in 6 lug?
Should I just "suck it up" and convert to 5 lug? My rear end has been changed at some point. It has a "hole" in the top part of the diff housing for a different style panhard bar. Not too sure that matters unless I do a 5 lug swap. I read the axle splines may be quirky...
Note: The truck is on jack stands and blocks in the picture. Also the motor is out. So the stance isn't accurate.
Raked 64 is offline   Reply With Quote
Old 05-25-2012, 06:04 PM   #2
chainsaw
chainsaw's Avatar
Re: Help me with wheels!
Cant help you but I like that orange. Crager does make a 6 spoke 6 lug wheel but its chrome.
chainsaw is offline   Reply With Quote
Old 05-25-2012, 06:54 PM   #3
CRGRS 66
CRGRS 66's Avatar
those boss wheels are reeeaaaally nice, and so is your 64! Changing to 5 lug really opens up your choices that is for certain.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-25-2012, 07:02 PM   #4
Raked 64
Raked 64's Avatar
Thank you! I have alot of hours in it.
Just about talked myself into swapping to 5 lug. Going to have to look at the rear end closer
Old 05-25-2012, 07:05 PM   #5
CRGRS 66
CRGRS 66's Avatar
I am in the process of machining, cleaning, and painting some late 70's off road wheels, I will be adding beauty rings and center caps, will chime back in with a pic when I am done.
Craigerrr
Old 05-26-2012, 06:09 PM   #6
forestb
forestb's Avatar
I think american racing wheels make a similar 6 lug 6 spoke wheel. You will have to contact them to see if they will fit your 6 lug pattern.
forestb is offline   Reply With Quote
Old 05-26-2012, 07:11 PM   #7
Fastest32
Fastest32's Avatar
I had those 338s on my 83 and loved them. Mine were chrome though. I'm pretty sure boss also make a six spoke one too though.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 05-26-2012, 08:32 PM   #8
McCoyAZ
McCoyAZ's Avatar
I kinda like the wheels you have on it now.
But i'm weird that way.
McCoyAZ is offline   Reply With Quote
Old 05-26-2012, 09:54 PM   #9
Snowbound
Snowbound's Avatar
Summit Racing has a 6 lug wheel in that style in their catalogue.
Truck looks great!
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 05-27-2012, 08:51 AM   #10
Raked 64
Raked 64's Avatar
Thanks guys ! The wheels I have now are ok. But I would have to trim the fender flange As the offset is a little off. I don't wanna trim anything. Plus I am ready for a new look:-)
Old 08-11-2012, 11:28 AM   #11
Raked 64
Raked 64's Avatar
Talking Re: Help me with wheels!
I have decided to buy the Boss wheels. I plan to go 20x8 front and 20x10 rear.
I have uncut wheel flanges in the rear. I am thinking 4.5" backspace front and 5.5" backspace rear.
Tires: 275 rear? Anyone know what will fit ?
Front: 255?
Please let me know if you have a proven tire size and wheel backspace.
I would rather not reinvent the wheel ! Lol
Old 08-11-2012, 11:57 AM   #12
hardwaa
hardwaa's Avatar
Be careful with these 338's. I call them 666's. There is more than meets the eye with these wheels. Do not plan on them just "BOLTING ON".
There is a thread about these wheels on this forum.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 08-11-2012, 05:54 PM   #13
GMC66
GMC66's Avatar
Agreed on you had better research prior to buying. They can be tricky. Do a search on this forum, lots on info. These wheels will be on my 66 soon...
GMC66 is offline   Reply With Quote
Old 08-11-2012, 08:09 PM   #14
Raked 64
Raked 64's Avatar
Yikes!! Boss look to be a pain...
Here's what I learned from a search and a lot of reading....
Boss: Poor design and some mods needed to make them work.
Coy wheels: bolt up
Cons of both Coy and Boss: Added material to the rear of the hub to change backspacing. This means that the Wheel lip is not nearly as deep as I like.
I am currently looking at Showwheels . They seem to bolt up and have a deeper wheel lip.
I did a search and didn't see many threads regarding Showwheels. the specs on their website seem to indicate a deeper lip with roughly the same look?
Can anyone confirm this?
Old 08-12-2012, 12:57 AM   #15
likaroc13
Rollin' Old Skool
you might check out these too:
http://www.jdwheels.com/ridler_racing.htm
i don't know anything about them, but they were mentioned on an S-10 forum i frequent
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 08-12-2012, 01:10 AM   #16
Mike Bradbury
Mike Bradbury's Avatar
I have 18" Coys and they work great. I switched from 8 lug to 5 for varoius reasons but a big part was better wheel choice than converting to 6 lug.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 08-12-2012, 01:22 AM   #17
westcoast5
Im about to pull the trigger on those boss 338 for me but Im wondering of how deep a lip will I get and still be able to lay the body flat on the ground.
Bryan
1966 SWB BBW "SICKT6"
Accuair|Porterbuilt|Bodied|Shaved|Z'd|350 with minor goodies|5 lug|front disc|3.73 rear|CPP power steering/brakes|few more goodies| thanks to C10Clubapparel
westcoast5 is offline   Reply With Quote
Old 08-12-2012, 12:56 PM   #18
Raked 64
Raked 64's Avatar
I am converting to 5 lug and have a CPP front disc conversion and drop spindles.
Would be nice to know if someone else is already running the Showwheels on a 64-66 C-10.
Anyone know?
Old 08-12-2012, 01:28 PM   #19
SCOTI
SCOTI's Avatar
Anyone know?
One of your original questions was concerning the rear end & I haven't seen any updated info posted.... If there's a 'boss' on the top right hand side of the housing for a stud, the housing is most likely swapped from a 66 or later truck. That being said, you need to determine if the housing is the shorter (pre-71) or longer (mid 70-72) unit. Your backspacing needs will depend on which housing for best fit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
