Old 05-13-2003, 07:26 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
bumper brackets ?'s
Finally broke down and bought me a new Goodmark bumper for the rear of my 69. When my grandpa had the truck on the farm they just welded up a bumper that would work. so i ahve no brackets and i went to the local junk yard and they only have 4 trucks that ive pretty well robbed all the parts so far off of. So now I'm wondering is there any other model years that will work for brackets the bumper only has 2 holes per side too
attached a pic of the bumper i hope
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 05-13-2003, 08:51 PM   #2
casey
casey's Avatar
I bought my brackets from scotts super truck in penhold, If Im not mistaken they were like 25 bucks each, by the time you piss around trying to make them, and usually the bracket you make doesn't fit the contour of the bumper right
casey is offline   Reply With Quote
Old 05-13-2003, 08:54 PM   #3
pissonNOS
senior member
pissonNOS's Avatar
so 100$
for all the brackets and to drive up there rrrr im too cheap i guess
69 GMC bagged
Old 05-13-2003, 09:04 PM   #4
dons72
dons72's Avatar
I'm sure that there are some board members that sell them. LMC has the whole set for $60 if not, and they are often high on their prices.
72 cheyenne super
dons72 is offline   Reply With Quote
Old 05-13-2003, 09:21 PM   #5
Jason71k10
ready for reassembly
Jason71k10's Avatar
pissonNOS, I don't know if you were gonna try to make some, but unless you have a set to use as a model(which you obviously don't), it's really hard to get the proper angles and get the holes drilled in the right spot.......i know, cuz I tried to make some!!! let's just say that I think i'll be buying a set in the future
good luck
Jason
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
Old 05-13-2003, 09:29 PM   #6
Class of 69
Class of 69's Avatar
Put a 'want to buy" add on the parts board. You'll probably get a few offers to choose from. The rear brackets aren't that uncommon.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-13-2003, 10:05 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
Jason71K10
what i was planning to do is since I already have brackets of the exact angle (farmer fix) was to cut them off at the bumper and weld 2 21inch x 3 inch and the weld that to the other brackets on my frame ?
69 GMC bagged
Old 05-13-2003, 10:06 PM   #8
Tim Christian
Tim Christian's Avatar
I have the complete Bumper Bracket kit in stock for $50.00 Let me know if I can help you. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 05-13-2003, 10:13 PM   #9
pissonNOS
senior member
pissonNOS's Avatar
Tim I sent you a PM
69 GMC bagged
Old 05-13-2003, 10:30 PM   #10
pissonNOS
senior member
pissonNOS's Avatar
tim sent u another
69 GMC bagged
